Installing multiple instances
I’m wondering if there’s an easy way to use Umbrel as a web server. I’m not very tech-savvy, so I might use some incorrect terms here. I’m looking for a simpler interface, like Hostinger or a web hosting panel, where I can set up multiple WordPress instances and test them. My goal is to use it as my personal server while building WordPress websites.
I noticed there’s a WordPress app in the Umbrel app market, but it seems I can’t install more than one instance.
On top of that, I want to explore Frappe ERP builder, so I’m considering adding multiple Docker instances to experiment with. I checked out Coolify, but it feels a bit too technical for me, and I still need to improve my understanding of Docker concepts.
well you need to install a real os for this. Umbrel is a docker container program.
I would suggest running Debian if you are new to Linux
Then from there you install apache or nginx, php, and mysql then you can run as many as you want.
