Debian 10 and Plesk Obsidian
Hi there.
Is it possible to install Umbrel on a server running Debian 10.13 with
Plesk Obsidian and several domains (with apache, nigx, php, etc) already running?
Will the hosting go down or will Plesk stop working?
I would like to set up a BTC node on this machine but I need everything else to keep working.
Thanks in advance for any help.
Yep should be fine to install to it’s own directory.
Not sure if you’ll have any issues with that old Debian distribution, but Umbrel should be able to update the relevant packages for installation, let us know if there’s any trouble.
