Hello, I have a PC running WIndows 10, and I would like to install the UMBREL virtual machine (VM) on it. However, I cannot find any instructions to help me achieve this. I’d appreciate if someone could send me the link to where I can obtain the relevant information/instructions, to install UMBREL VM on a Windows PC. Many Thanks
I want to do the same
Check this VMware player that installs on Windows10, to run ubuntu …and let me know if it works for anyone ![]()
I actually just did this a couple weeks ago and it’s both easy and is working well (so far). What I did:
- Install and configure latest version of Ubuntu from the Windows store (https://ubuntu.com/tutorials/install-ubuntu-on-wsl2-on-windows-10#1-overview)
- Open Ubuntu on Windows
- Follow instructions on the Umbrel homepage (ie enter
curl -L https://umbrel.sh | bashinto the Ubuntu shell / terminal and press Enter)
Good luck!
Edit on Sept 19, 2022: Although this worked initially, I am now unable to access the Umbrel dashboard from either the host machine or a different computer on the same dashboard. Not sure if this is just a general configuration issue or if it is related to running Umbrel on a Windows machine (WSL).
