Can I run Windows 10 or 11 on Umbrel Home server?
I all. I’m new with Umbrel, and this is my first post.
I want to buy an Umbrel Home server and run UmbrelOS on it as planned.
But I will also need a Windows mini PC (10 or 11) for a month or two.
So I was wondering if I could install Windows 10/11 on Umbrel Home for the short time I’ll need it, then install UmbrelOS once I no longer need the Windows mini-PC.
I could possibly swap the 2TB SSD for a 500GB SSD where I would install Windows, and later put the 2TB SSD back and continue with UmbrelOS.
Thanks in advance for your wise answers
You should be able to install pretty much any system on Umbrel Home server that supports x86 architecture. However, I’m afraid that you can only access the Umbrel Home’s graphical output if you open the server and take it out of the plastic case.
Thanks Django for the quick reply.
Yep I saw in a video there is a hidden HDMI port inside
Ok, I’ll try that
