lnbits
Attaching to lnbits_app_proxy_1, lnbits_web_1, lnbits_tor_server_1
app_proxy_1 | [HPM] Proxy created: / -> http://lnbits_web_1:3007
app_proxy_1 | Waiting for lnbits_web_1:3007 to open…
app_proxy_1 | LNbits is now ready…
app_proxy_1 | Listening on port: 3007
web_1 | 2023-03-06 10:45:42.78 | INFO | Task: pending check finished for 0 payments (took 0.001 s)
web_1 | 2023-03-06 11:15:42.77 | INFO | Task: checking all pending payments (incoming=False, outgoing=True) of last 15 days
web_1 | 2023-03-06 11:15:42.77 | INFO | Task: pending check finished for 0 payments (took 0.001 s)
web_1 | 2023-03-06 11:45:42.76 | INFO | Task: checking all pending payments (incoming=False, outgoing=True) of last 15 days
web_1 | 2023-03-06 11:45:42.77 | INFO | Task: pending check finished for 0 payments (took 0.001 s)
web_1 | 2023-03-06 12:15:42.75 | INFO | Task: checking all pending payments (incoming=False, outgoing=True) of last 15 days
web_1 | 2023-03-06 12:15:42.75 | INFO | Task: pending check finished for 0 payments (took 0.001 s)
web_1 | 2023-03-06 12:45:42.75 | INFO | Task: checking all pending payments (incoming=False, outgoing=True) of last 15 days
web_1 | 2023-03-06 12:45:42.75 | INFO | Task: pending check finished for 0 payments (took 0.001 s)
web_1 | 2023-03-06 12:46:45.38 | INFO | ::ffff:10.21.0.1:0 - “GET / HTTP/1.1” 200
lnplus
Attaching to lnplus_app_proxy_1, lnplus_tor_server_1, lnplus_web_1
web_1 | => Rails 7.0.3.1 application starting in development
web_1 | => Run bin/rails server --help for more startup options
web_1 | Puma starting in single mode…
web_1 | * Puma version: 5.6.4 (ruby 3.0.1-p64) (“Birdie’s Version”)
web_1 | * Min threads: 5
web_1 | * Max threads: 5
web_1 | * Environment: development
web_1 | * PID: 1
web_1 | * Listening on http://0.0.0.0:3777
web_1 | Use Ctrl-C to stop
app_proxy_1 | [HPM] Proxy created: / -> http://lnplus_web_1:3777
app_proxy_1 | Waiting for lnplus_web_1:3777 to open…
app_proxy_1 | Lightning Network+ is now ready…
app_proxy_1 | Listening on port: 3777
nostr-relay
Attaching to nostr-relay_relay_1, nostr-relay_app_proxy_1, nostr-relay_web_1, nostr-relay_tor_server_1
web_1 | {“level”:“info”,“ts”:1678068920.4438558,“msg”:“using provided configuration”,“config_file”:"/etc/caddy/Caddyfile",“config_adapter”:“caddyfile”}
web_1 | {“level”:“warn”,“ts”:1678068920.446018,“msg”:“Caddyfile input is not formatted; run the ‘caddy fmt’ command to fix inconsistencies”,“adapter”:“caddyfile”,“file”:"/etc/caddy/Caddyfile",“line”:7}
web_1 | {“level”:“info”,“ts”:1678068920.4501143,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“localhost:2019”,“enforce_origin”:false,“origins”:["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
web_1 | {“level”:“info”,“ts”:1678068920.45203,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc0004127e0”}
web_1 | {“level”:“info”,“ts”:1678068920.4533758,“logger”:“tls”,“msg”:“cleaning storage unit”,“description”:“FileStorage:/data/caddy”}
web_1 | {“level”:“info”,“ts”:1678068920.453431,“logger”:“http.log”,“msg”:“server running”,“name”:“srv0”,“protocols”:[“h1”,“h2”,“h3”]}
web_1 | {“level”:“info”,“ts”:1678068920.4540415,“logger”:“tls”,“msg”:“finished cleaning storage units”}
web_1 | {“level”:“error”,“ts”:1678068920.4540741,“msg”:“unable to autosave config”,“file”:"/config/caddy/autosave.json",“error”:“open /config/caddy/autosave.json: permission denied”}
web_1 | {“level”:“info”,“ts”:1678068920.454087,“msg”:“serving initial configuration”}
web_1 | {“level”:“info”,“ts”:1678106805.1032827,“logger”:“http.log.access.log0”,“msg”:“handled request”,“request”:{“remote_ip”:“10.21.0.15”,“remote_port”:“56874”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“172.30.223.24:4848”,“uri”:"/",“headers”:{“Accept-Language”:[“en-US,en;q=0.9”],“Accept-Encoding”:[“gzip, deflate”],“User-Agent”:[“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36”],“Connection”:[“close”],“X-Forwarded-Proto”:[“http”],“X-Forwarded-Host”:[“172.30.223.24:4848”],“Accept”:["/"],“X-Forwarded-For”:["::ffff:10.21.0.1"]}},“user_id”:"",“duration”:0.02328965,“size”:365,“status”:200,“resp_headers”:{“Content-Type”:[“text/html; charset=utf-8”],“Last-Modified”:[“Mon, 06 Feb 2023 12:09:28 GMT”],“Content-Encoding”:[“gzip”],“Vary”:[“Accept-Encoding”],“Server”:[“Caddy”],“Etag”:["“rpnr3sge”"]}}
relay_1 | Mar 06 12:38:20.097 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 54.07µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:39:20.098 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 51.939µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:40:20.099 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 59.49µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:41:20.101 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 67.249µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:42:20.102 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 96.969µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:43:20.104 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 77.12µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:44:20.105 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 56.68µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:45:20.106 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 65.27µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:46:20.108 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 63.39µs (result: Ok, WAL size: 0)
relay_1 | Mar 06 12:47:20.109 INFO nostr_rs_relay::repo::sqlite: checkpoint ran in 72.38µs (result: Ok, WAL size: 0)
app_proxy_1 | [HPM] Proxy created: / -> http://nostr-relay_web_1:3000
app_proxy_1 | Waiting for nostr-relay_web_1:3000 to open…
app_proxy_1 | Nostr Relay is now ready…
app_proxy_1 | Listening on port: 4848
tailscale
Attaching to tailscale_web_1, tailscale_tor_server_1
web_1 | 2023/03/06 12:47:21 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=9700, table=254
web_1 | 2023/03/06 12:47:21 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”)
web_1 | 2023/03/06 12:47:34 monitor: RTM_DELROUTE: src=, dst=fe80::e4ac:62ff:fe1c:d140/128, gw=, outif=9704, table=254
web_1 | 2023/03/06 12:47:34 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=9704, table=254
web_1 | 2023/03/06 12:47:34 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”)
web_1 | 2023/03/06 12:47:47 [RATELIMIT] format(“monitor: %s: src=%v, dst=%v, gw=%v, outif=%v, table=%v”) (1 dropped)
web_1 | 2023/03/06 12:47:47 monitor: RTM_DELROUTE: src=, dst=fe80::3014:7dff:feaa:4345/128, gw=, outif=9706, table=254
web_1 | 2023/03/06 12:47:47 monitor: RTM_DELROUTE: src=, dst=fe80::/64, gw=, outif=9706, table=254
web_1 | 2023/03/06 12:47:47 monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw=, outif=9706, table=254
thunderhub
Attaching to thunderhub_app_proxy_1, thunderhub_web_1, thunderhub_tor_server_1
app_proxy_1 | [HPM] Proxy created: / -> http://thunderhub_web_1:3000
app_proxy_1 | Waiting for thunderhub_web_1:3000 to open…
app_proxy_1 | ThunderHub is now ready…
app_proxy_1 | Listening on port: 3000
web_1 | {
web_1 | message: ‘UnableToConnectToAnyNode’,
web_1 | level: ‘error’,
web_1 | timestamp: ‘2023-03-06T02:15:23.482Z’
web_1 | }
web_1 | {
web_1 | message: 'Initiating subscriptions failed: ',
web_1 | timestamp: ‘2023-03-06T02:15:23.483Z’
web_1 | }
==== Result ====
