I wonder where my Sats went?
While I was syncing the blockchain on my Pi 4 I sent about $10 bucks to the Umbrel Bitcoin Wallet. The $10 did show up in the wallet just fine.
Before syncing was complete my SSD failed so I had to start over. I figured, no problem just start over with the original 24 seed words and my $10 will be in the wallet… NOT! I’ve even waited for the blockchain to be 100% synced on the new 1TB SSD but the Umbrel Bitcoin Wallet still showed a zero balance.
Umbrel afaik only shows new incoming transactions, if you go and check the wallet balance or load the seed words into BlueWallet then you can view the current balance. You didn’t lose anything.
