Hello guys! ![]()
I am having some trouble with configuring my Umbrel node. I recently set up Umbrel on my Raspberry Pi, and everything seemed to be going smoothly until I reached the node synchronization stage. My node seems to be stuck and isn’t progressing as expected.
I have checked my internet connection and rebooted the device several times, but the issue persists. I am wondering if there’s something specific I might be missing or if there are any common troubleshooting steps I should follow.
I also check this: https://community.umbrel.com/t/home-assistant-configuration-yaml-nuked-during-umbrel-restartsnowflake But I have not found any solution. Could anyone guide me the solution. If anyone has experienced something similar or has any advice on how to resolve this, I’d really appreciate your help. Thanks in advance for any guidance you can provide!
Thanks in advance! ![]()
Respected community member ![]()
