0.4.9
Flashed OS version
v0.4.14
Raspberry Pi Model
Revision : d03114
Serial : 10000000eee8040e
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=49.1’C
Throttling
throttled=0x0
Mem: 7.8G 139M 7.3G 8.0M 389M 7.5G
Swap: 4.1G 0B 4.1G
total: 1.8%
system: 1.8%
tor: 0%
thunderhub: 0%
ride-the-lightning: 0%
photoprism: 0%
lnd: 0%
lightning-terminal: 0%
electrs: 0%
bluewallet: 0%
bitcoin: 0%
Memory monitor logs
2022-03-04 12:32:43 Memory monitor running!
2022-03-04 12:32:55 Memory monitor running!
2022-03-04 12:33:07 Memory monitor running!
2022-03-04 12:33:18 Memory monitor running!
2022-03-04 12:33:30 Memory monitor running!
2022-03-04 12:33:42 Memory monitor running!
2022-03-04 12:33:54 Memory monitor running!
2022-03-04 12:34:06 Memory monitor running!
2022-03-04 12:34:18 Memory monitor running!
2022-03-04 12:34:30 Memory monitor running!
/dev/root 30G 3.3G 25G 12% /
/dev/sda1 916G 507G 363G 59% /home/umbrel/umbrel
Startup service logs
Mar 04 12:34:32 umbrel umbrel startup[29583]: The NGINX_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The BITCOIN_P2P_PORT variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The BITCOIN_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The LND_REST_PORT variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The LND_GRPC_PORT variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The LND_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The DASHBOARD_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The MIDDLEWARE_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The BITCOIN_RPC_PORT variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The BITCOIN_RPC_USER variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The BITCOIN_RPC_PASS variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The BITCOIN_NETWORK variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The MANAGER_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The NEUTRINO_SWITCHER_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The ELECTRUM_PORT variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The ELECTRUM_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Mar 04 12:34:32 umbrel umbrel startup[29583]: The Compose file ‘./docker-compose.yml’ is invalid because:
Mar 04 12:34:32 umbrel umbrel startup[29583]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Mar 04 12:34:32 umbrel umbrel startup[29583]: services.tor.ports contains an invalid type, it should be a number, or an object
Mar 04 12:34:32 umbrel umbrel startup[29583]: services.bitcoin.ports contains an invalid type, it should be a number, or an object
Mar 04 12:34:32 umbrel umbrel startup[29583]: services.electrs.ports contains an invalid type, it should be a number, or an object
Mar 04 12:34:32 umbrel umbrel startup[29583]: services.lnd.ports contains an invalid type, it should be a number, or an object
Mar 04 12:34:32 umbrel umbrel startup[29583]: services.nginx.ports contains an invalid type, it should be a number, or an object
Mar 04 12:34:32 umbrel umbrel startup[29583]: services.lnd.ports value [‘9735:9735’, ‘:’, ‘:’] has non-unique elements
Mar 04 12:34:32 umbrel umbrel startup[29583]: Failed to start containers
Mar 04 12:34:32 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Mar 04 12:34:32 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Mar 04 12:34:32 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Mar 04 12:34:40 umbrel systemd[1]: Stopped Umbrel Startup Service.
External storage service logs
– Logs begin at Fri 2022-03-04 12:17:53 UTC, end at Fri 2022-03-04 13:36:36 UTC. –
Mar 04 12:17:57 umbrel systemd[1]: Starting External Storage Mounter…
Mar 04 12:17:58 umbrel external storage mounter[487]: Running external storage mount script…
Mar 04 12:17:58 umbrel external storage mounter[487]: Found device “CT1000MX 500SSD1”
Mar 04 12:17:58 umbrel external storage mounter[487]: Blacklisting USB device IDs against UAS driver…
Mar 04 12:17:58 umbrel external storage mounter[487]: Rebinding USB drivers…
Mar 04 12:17:58 umbrel external storage mounter[487]: Checking USB devices are back…
Mar 04 12:17:58 umbrel external storage mounter[487]: Waiting for USB devices…
Mar 04 12:17:59 umbrel external storage mounter[487]: Waiting for USB devices…
Mar 04 12:18:00 umbrel external storage mounter[487]: Checking if the device is ext4…
Mar 04 12:18:01 umbrel external storage mounter[487]: Yes, it is ext4
Mar 04 12:18:01 umbrel external storage mounter[487]: Checking if device contains an Umbrel install…
Mar 04 12:18:01 umbrel external storage mounter[487]: Yes, it contains an Umbrel install
Mar 04 12:18:01 umbrel external storage mounter[487]: Bind mounting external storage over local Umbrel installation…
Mar 04 12:18:01 umbrel external storage mounter[487]: Bind mounting external storage over local Docker data dir…
Mar 04 12:18:01 umbrel external storage mounter[487]: Bind mounting external storage to /swap
Mar 04 12:18:01 umbrel external storage mounter[487]: Bind mounting SD card root at /sd-card…
Mar 04 12:18:01 umbrel external storage mounter[487]: Checking Umbrel root is now on external storage…
Mar 04 12:18:02 umbrel external storage mounter[487]: Checking /var/lib/docker is now on external storage…
Mar 04 12:18:02 umbrel external storage mounter[487]: Checking /swap is now on external storage…
Mar 04 12:18:02 umbrel external storage mounter[487]: Setting up swapfile
Mar 04 12:18:02 umbrel external storage mounter[487]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Mar 04 12:18:02 umbrel external storage mounter[487]: no label, UUID=a84a6972-9d0a-49eb-93d0-6629f3c1817e
Mar 04 12:18:02 umbrel external storage mounter[487]: Checking SD Card root is bind mounted at /sd-root…
Mar 04 12:18:02 umbrel external storage mounter[487]: Starting external drive mount monitor…
Mar 04 12:18:02 umbrel external storage mounter[487]: Mount script completed successfully!
Mar 04 12:18:02 umbrel systemd[1]: Started External Storage Mounter.
Mar 04 12:18:14 umbrel external storage updater[990]: Configuring new release
Mar 04 12:18:15 umbrel external storage updater[990]: ======================================
Mar 04 12:18:15 umbrel external storage updater[990]: =========== RECONFIGURING ============
Mar 04 12:18:15 umbrel external storage updater[990]: ========= UMBREL (mainnet) ===========
Mar 04 12:18:15 umbrel external storage updater[990]: Generating auth credentials
Mar 04 12:18:15 umbrel external storage updater[990]: Generating Tor password
Mar 04 12:18:16 umbrel external storage updater[990]: Unable to find image ‘getumbrel/tor:v0.4.1.9’ locally
Mar 04 12:18:31 umbrel external storage updater[990]: docker: Error response from daemon: Get “https://registry-1.docker.io/v2/”: context deadline exceeded.
Mar 04 12:18:31 umbrel external storage updater[990]: See ‘docker run --help’.
Mar 04 12:18:31 umbrel external storage updater[990]: == End Update Script 01-run.sh ==
Mar 04 12:18:31 umbrel external storage updater[990]: == Begin Update Script 02-run.sh ==
Mar 04 12:18:31 umbrel external storage updater[990]: =======================================
Mar 04 12:18:31 umbrel external storage updater[990]: =============== UPDATE ================
Mar 04 12:18:31 umbrel external storage updater[990]: ========= Stage: Post-update ==========
Mar 04 12:18:31 umbrel external storage updater[990]: == End Update Script 02-run.sh ==
Mar 04 12:18:31 umbrel external storage updater[990]: == Begin Update Script 03-run.sh ==
Mar 04 12:18:31 umbrel external storage updater[990]: =========== Stage: Success ============
Mar 04 12:18:31 umbrel external storage updater[990]: Removing backup
Mar 04 12:18:31 umbrel external storage updater[990]: Successfully installed Umbrel 0.4.14
Mar 04 12:18:31 umbrel external storage updater[990]: == End Update Script 03-run.sh ==
Mar 04 12:18:31 umbrel external storage updater[990]: Deleting cloned repository
Mar 04 12:18:31 umbrel external storage updater[990]: Removing lock
Mar 04 12:18:31 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Bitcoin Core logs
LND logs
electrs logs
Tor logs
App logs
bluewallet
ERROR: Couldn’t find env file: /home/umbrel/umbrel/.env
lightning-terminal
photoprism
ride-the-lightning
thunderhub
==== Result ====
