Hi guys, I need your help…
I tried lot of things but nothing works… Here is my report :
0.4.18
Flashed OS version
v0.5.0
Raspberry Pi Model
Revision : d03114
Serial : 10000000c516460e
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=40.4’C
Throttling
throttled=0x0
Mem: 7.8G 158M 7.2G 8.0M 417M 7.5G
Swap: 4.1G 0B 4.1G
total: 2.0%
system: 2%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
1853 ? S 0:00 bash ./scripts/memory-monitor
/dev/root 29G 3.1G 25G 12% /
/dev/sda1 916G 523G 348G 61% /home/umbrel/umbrel
Startup service logs
Jun 13 08:48:52 umbrel umbrel startup[7291]: The ELECTRUM_PORT variable is not set. Defaulting to a blank string.
Jun 13 08:48:52 umbrel umbrel startup[7291]: The ELECTRUM_IP variable is not set. Defaulting to a blank string.
Jun 13 08:48:52 umbrel umbrel startup[7291]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Jun 13 08:48:52 umbrel umbrel startup[7291]: The Compose file ‘./docker-compose.yml’ is invalid because:
Jun 13 08:48:52 umbrel umbrel startup[7291]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Jun 13 08:48:52 umbrel umbrel startup[7291]: services.tor_proxy.ports contains an invalid type, it should be a number, or an object
Jun 13 08:48:52 umbrel umbrel startup[7291]: services.bitcoin.ports contains an invalid type, it should be a number, or an object
Jun 13 08:48:52 umbrel umbrel startup[7291]: services.electrs.ports contains an invalid type, it should be a number, or an object
Jun 13 08:48:52 umbrel umbrel startup[7291]: services.lnd.ports contains an invalid type, it should be a number, or an object
Jun 13 08:48:52 umbrel umbrel startup[7291]: services.nginx.ports contains an invalid type, it should be a number, or an object
Jun 13 08:48:52 umbrel umbrel startup[7291]: services.lnd.ports value [‘9735:9735’, ‘:’, ‘:’] has non-unique elements
Jun 13 08:48:52 umbrel umbrel startup[7291]: Failed to start containers
Jun 13 08:48:52 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Jun 13 08:48:52 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Jun 13 08:48:52 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Jun 13 08:49:02 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Jun 13 08:49:02 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 22.
Jun 13 08:49:02 umbrel systemd[1]: Stopped Umbrel Startup Service.
Jun 13 08:49:02 umbrel systemd[1]: Starting Umbrel Startup Service…
Jun 13 08:49:03 umbrel umbrel startup[7536]: ======================================
Jun 13 08:49:03 umbrel umbrel startup[7536]: ============= STARTING ===============
Jun 13 08:49:03 umbrel umbrel startup[7536]: ============== UMBREL ================
Jun 13 08:49:03 umbrel umbrel startup[7536]: Setting environment variables…
Jun 13 08:49:03 umbrel umbrel startup[7536]: Starting karen…
Jun 13 08:49:03 umbrel umbrel startup[7536]: Starting status monitors…
Jun 13 08:49:03 umbrel umbrel startup[7536]: Starting memory monitor…
Jun 13 08:49:03 umbrel umbrel startup[7536]: Starting backup monitor…
Jun 13 08:49:03 umbrel umbrel startup[7536]: Starting decoy backup trigger…
Jun 13 08:49:03 umbrel umbrel startup[7536]: Starting Docker services…
External storage service logs
– Logs begin at Mon 2022-06-13 08:26:41 UTC, end at Mon 2022-06-13 08:49:03 UTC. –
Jun 13 08:26:55 umbrel systemd[1]: Starting External Storage Mounter…
Jun 13 08:26:55 umbrel external storage mounter[485]: Running external storage mount script…
Jun 13 08:27:01 umbrel external storage mounter[485]: Found device “ASMT 2115”
Jun 13 08:27:01 umbrel external storage mounter[485]: Blacklisting USB device IDs against UAS driver…
Jun 13 08:27:01 umbrel external storage mounter[485]: Rebinding USB drivers…
Jun 13 08:27:01 umbrel external storage mounter[485]: Checking USB devices are back…
Jun 13 08:27:01 umbrel external storage mounter[485]: Waiting for USB devices…
Jun 13 08:27:02 umbrel external storage mounter[485]: Waiting for USB devices…
Jun 13 08:27:03 umbrel external storage mounter[485]: Waiting for USB devices…
Jun 13 08:27:04 umbrel external storage mounter[485]: Checking if the device is ext4…
Jun 13 08:27:09 umbrel external storage mounter[485]: Yes, it is ext4
Jun 13 08:27:09 umbrel external storage mounter[485]: Checking if device contains an Umbrel install…
Jun 13 08:27:09 umbrel external storage mounter[485]: Yes, it contains an Umbrel install
Jun 13 08:27:09 umbrel external storage mounter[485]: Bind mounting external storage over local Umbrel installation…
Jun 13 08:27:09 umbrel external storage mounter[485]: Bind mounting external storage over local Docker data dir…
Jun 13 08:27:09 umbrel external storage mounter[485]: Bind mounting external storage to /swap
Jun 13 08:27:10 umbrel external storage mounter[485]: Bind mounting SD card root at /sd-card…
Jun 13 08:27:10 umbrel external storage mounter[485]: Checking Umbrel root is now on external storage…
Jun 13 08:27:13 umbrel external storage mounter[485]: Checking /var/lib/docker is now on external storage…
Jun 13 08:27:13 umbrel external storage mounter[485]: Checking /swap is now on external storage…
Jun 13 08:27:13 umbrel external storage mounter[485]: Setting up swapfile
Jun 13 08:27:14 umbrel external storage mounter[485]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Jun 13 08:27:14 umbrel external storage mounter[485]: no label, UUID=b6940311-ec91-46d3-841e-947b207a4d23
Jun 13 08:27:14 umbrel external storage mounter[485]: Checking SD Card root is bind mounted at /sd-root…
Jun 13 08:27:14 umbrel external storage mounter[485]: Starting external drive mount monitor…
Jun 13 08:27:14 umbrel external storage mounter[485]: Mount script completed successfully!
Jun 13 08:27:14 umbrel systemd[1]: Started External Storage Mounter.
Jun 13 08:44:37 umbrel external storage updater[1001]: The NETWORK_IP variable is not set. Defaulting to a blank string.
Jun 13 08:44:37 umbrel external storage updater[1001]: The Compose file ‘./docker-compose.yml’ is invalid because:
Jun 13 08:44:37 umbrel external storage updater[1001]: networks.default.ipam.config.subnet is invalid: should use the CIDR format
Jun 13 08:44:37 umbrel external storage updater[1001]: services.tor_proxy.ports contains an invalid type, it should be a number, or an object
Jun 13 08:44:37 umbrel external storage updater[1001]: services.bitcoin.ports contains an invalid type, it should be a number, or an object
Jun 13 08:44:37 umbrel external storage updater[1001]: services.electrs.ports contains an invalid type, it should be a number, or an object
Jun 13 08:44:37 umbrel external storage updater[1001]: services.lnd.ports contains an invalid type, it should be a number, or an object
Jun 13 08:44:37 umbrel external storage updater[1001]: services.nginx.ports contains an invalid type, it should be a number, or an object
Jun 13 08:44:37 umbrel external storage updater[1001]: services.lnd.ports value [‘9735:9735’, ‘:’, ‘:’] has non-unique elements
Jun 13 08:44:37 umbrel external storage updater[1001]: Failed to start containers
Jun 13 08:44:37 umbrel external storage updater[1001]: == End Update Script 01-run.sh ==
Jun 13 08:44:37 umbrel external storage updater[1001]: == Begin Update Script 02-run.sh ==
Jun 13 08:44:37 umbrel external storage updater[1001]: =======================================
Jun 13 08:44:37 umbrel external storage updater[1001]: =============== UPDATE ================
Jun 13 08:44:37 umbrel external storage updater[1001]: ========= Stage: Post-update ==========
Jun 13 08:44:37 umbrel external storage updater[1001]: == End Update Script 02-run.sh ==
Jun 13 08:44:37 umbrel external storage updater[1001]: == Begin Update Script 03-run.sh ==
Jun 13 08:44:37 umbrel external storage updater[1001]: =========== Stage: Success ============
Jun 13 08:44:37 umbrel external storage updater[1001]: Removing backup
Jun 13 08:44:37 umbrel external storage updater[1001]: Successfully installed Umbrel 0.5.0
Jun 13 08:44:37 umbrel external storage updater[1001]: == End Update Script 03-run.sh ==
Jun 13 08:44:37 umbrel external storage updater[1001]: Deleting cloned repository
Jun 13 08:44:37 umbrel external storage updater[1001]: Removing lock
Jun 13 08:44:37 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
1881 ? S 0:00 bash ./karen
karen is already running
1842 ? S 0:00 bash ./karen
Docker containers
NAMES STATUS
Umbrel logs
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
Can u help me please ? Since the last failure update 0.5.0, I don’t succeed to enter on umbrel, always the same message : Failed to start containers.
Thanks for your help,
Maximka
