I cannot find a clear reconciliaton of fees paid/earned in umbrel
Hi
I was hoping to find a dashboard in umbrel , thunderhub or apps allowing a clear display and reconciliation of sats earned and paid on the channel activities. However i don’t see this. Our separate sat tracking of all movements shows some “ghost” sats i can’t account for which i suspect to be said fees. Any advice on the widget, dashboard, or location of clearly tracking fees?
I use Ride The Lightning
If you go into the Lightning tab in RTL, there is a Routing page that shows you payments that have been routed through your node.
Ta - its all there - i should have looked ))
