Upgrade to Umbrel 0.5 - Where's my Sat's?
Ok, I put my hands up for probably not having read all I should have prior to upgrading my Umbrel node.
I had a small amount of Bitcoin on my node which showed in the Bitcoin page under the old version. I can’t see anywhere to view the amount of Bitcoin held now. Am I missing something? Do I need to install or connect a BTC wallet?
Have a look under Lightning Node.
Thanks for that. Yep, sure enough my Sats are there under Lightning node.
Not a very intuitive change but I can roll with that. Is there some sort of reasoning behind the change here? I get there may be an assumption that people might ONLY want or need to send BTC over lightning. But I’m not running any lightning channels.
Ditto. Not intuitive when there is a Bitcoin Node app. Thanks for posting the question. It totally helped.
