My 0.5.4 install on top of Ubuntu in a Proxmox VM, I have a 2TB SSD mounted for the Umbrel installation. The Bitcoin Node is currently using 785gb to store the blockchain. It begs the question I can’t seem to find any answer to, is how will a small data mount point hold the block chain?
The migration procedure has you back up to an external USB drive, and I question if that include the huge blockchain.
Do I need to blow off my 2tb ssd and need to resync the chain? Because it seems that way to me.
Hello, I am a total beginner. I managed to install the new version and also install the update.
Of course I also have a backup of the older version 0.5.4.
How can I now transfer the data to version 1.2?
Actually, I only have immich in there, but there is a lot of data.
Can anyone help me?
Thank you very much for the tutorial. My only observation is, I think it is important to clarify that the image needed for the successful configuration is:
I don’t mean to necro a thread- great guide! If I’m looking to start something that I know is going to need more than 32GB storage (say, a BTC node), should I just give it more in advance?
Let’s say I’m a big dummy and didn’t do that ahead of time. How would I add more space?
