How to first boot with only W-lan?
In the past, you could load a wpa...conf file containing your Wi-Fi credentials into the boot folder and connect via Wi-Fi immediately.
This is no longer possible in 2025/2026. An older version of the software is no longer available for download.
WTF!
How can I get Umbrel working again without Ethernet/LAN, using only Wi-Fi?
you can’t
Attach a USB Keyboard and Monitor should work to login via ssh. From there, you would need to configure network via CLI.
First of all, you should be able to download olders versions of Umbrel OS here: Releases · getumbrel/umbrel · GitHub
Second, I’d try with wpa_supplicant + systemd service + dhcp
You will need to use a terminal or login locally to Umbrel via SSH or comm port.
Use;
sudo nmcli device wifi connect (SSID) (password)
Use a known ssid in the area shown, and the password for that ssid… it will auto connect after reboot as well…
