How to connect to wifi with umbrel home?
I tried this
but umbrel home can’t run the wifi connection
Am I using the wrong path or file(/boot/wpa_supplicant.conf)?
Hi, for the Umbrel Home you can use this:
nmcli device wifi connect <your-ssid> password <your-password>
Thank you.
I tried your suggestion and succeeded in using wifi.
Hey @ichinaka, the first public beta of umbrelOS 1.2 officially brings Wi-Fi support. To test out the update on an existing Umbrel, go to Settings > Advanced settings, and enable umbrelOS Beta Program. You’ll then see “umbrelOS 1.2 Beta 1” being available for update. After update, you can connect to your Wi-Fi from Settings > Wi-Fi.
Please keep us posted with how it goes for you!
