Can't connect to wifi after update to OS1.0.4
My Umbrel was connected to wifi prior to the OS update to 1.0.4. After the update it only connects with ethernet and even after I re-add the wpa_supplicant.conf file in the SD card, it is still not connecting.
Please see the following:
This worked great, thank you!
I had to change the ssid and pwd sintax to the following,
sudo nmcli device wifi connect ‘ssid_name’ password ‘mypassw123’
instead of using the <>
