How to change the default password for Ride the Lightning?
Does anyone know? I tried going to the settings and then authentication section but not sure why it’s not showing how or where to change the password? It just shows how to enable 2FA.
Andy1 sent me a message and said the below but doesn’t seem right and seems fishy as the underlying URL doesn’t even seem official. Posting here for visibility
@TheDecentralizedVet This is a well known issue, i had a similar issue just like this but it have been resolved. i will highly suggest you talk directly with a representative from umbrel to help you resolve this right away. this is the support platform UMBREL LIVE SUPPORT AGENT to talk directly with a representative from umbrel .
Note: click on the live chat icon at the bottom corner of the page to start a conversation with a representative from umbrel .
So basically they helped me resolve this same issue that is why i thought i should share this with you, if you are still in need of assistance
@mayank is the above a scam or legit?
Seems like it is based on this
Yes it is obviously a scam!
For you original question I don’t know I will try to check later.
