I have already opened channels.
Now need add more liquidity to channel on already opened channel
How i can do that?
you can’t enlarge an existing channel. You have only one option. you measure a new size channel open.
In the Guides section are tons of links with documentation about how LN works.
Did you tried at least these two?
As I said in the Getting started with Umbrel node guide - it is very important to start reading about these things BEFORE doing anything else with your node. Will save you a lot of trouble.
