I accidentally unplugged my Rasip while BTC was still syncing. Now it just looks like this for the last 8 hours. Not sure what to do. Please any help. Thank you
I have tried this but it didn’t work?
ssh into your node:
ssh umbrel@umbrel.local
then remove these two files (likely corrupted by bad shutdown), one command at a time:
sudo rm ./umbrel/app-data/bitcoin/data/bitcoin/settings.json
sudo rm ./umbrel/app-data/bitcoin/data/bitcoin/peers.dat
then reboot:
sudo reboot
I get “No such file or directory”
