I think i turned of my Rasberry Pi 4 the wrong way and it may have caused damage to my files or something like that. I was almost finished syncing my node. Any help to fix this issue? thanks
We need a little more info here to be able to help out. Can you supply a debug? Did the node start syncing blocks then stop or did it never start syncing?
