I’m running a local Bitcoin full node on Umbrel with Public Pool set up and working smoothly. Now, I’m looking to enable Merged Mining for other compatible coins (e.g., Namecoin, Dogecoin) directly on my local pool.
- Has anyone successfully configured Merged Mining on their local Umbrel setup?
- If yes, what tools, apps, or configurations did you use?
- Are there any key challenges or limitations I should be aware of?
I’m open to any solutions or insights, regardless of the specific software used. Thanks in advance for sharing your experiences!
