Verify public pool is using my bitcoin address
I’ve ordered a nerdminer and I’m planning to point at my umbrel node, with public pool.
This will be my first foray into mining, so this may be a naive question.
I know the odds are astronomical, but if it ever did it would be a shame if it was configured incorrectly, or if public pool had tampered with the address.
How do I verify it’s mining with my correct information?
Thanks
So this is up and running now. When I flashed the nerdminer I could see it was submitting shares. I guess I need to find a way to inspect a share. Anyone know how or another way to confirm?
You can just open public-pool, type your BTC address as login, and check if your miners are seen by public-pool and active;
Thanks for your reply.
I can see that public pool says my miner is associated with my bitcoin address.
Maybe I’m paranoid :slight_smile:
But I want to independently verify that is what’s actually used
Well you would need to ssh into you umbrel node, and inspect the Public-Pool logs and search for strings like :
“payout address”: “bc1qd…”
“coinbase transaction”: “bc1qd…”
“block template” : “bc1qd…”
with your BTC adress
I’m sorry I can’t help further, as I never connected to my umbrel node through ssh and don’t know the locations of the files we are looking for …
I think there are tutorials about this on these pages …
Thanks, that’s very helpful.
I’ll try and locate the logs and report back
You’re welcome,
I also want to mention, I had a question more or less similar to yours, and got an interesting answer from denny, you may want to check this thread:
Thanks - it looks like I shouldn’t worry about it :slight_smile:
