Hello Guys
i was able to set up my acount in umbrel. suddendly i got stuck in this screen.
i tried reformartting the SD card several times
here is the log debug
0.3.10
Umbrel OS version
v0.3.10
Raspberry Pi Model
Revision : c03112
Serial : 100000000985a4bf
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
Feb 25 2021 12:10:40
Copyright (c) 2012 Broadcom
version 564e5f9b852b23a330b1764bcf0b2d022a20afd0 (clean) (release) (start)
Temperature
temp=77.9’C
Throttling
throttled=0x20000
Mem: 3.8G 1.1G 990M 7.0M 1.7G 2.6G
Swap: 4.1G 2.0M 4.1G
bitcoin: 39.9%
total: 29.7%
tor: 0.6%
system: 0%
lnd: 0%
electrs: 0%
/dev/root 118G 2.7G 110G 3% /
/dev/sda1 1.8T 93G 1.7T 6% /home/umbrel/umbrel
Startup service logs
May 21 10:56:57 umbrel umbrel startup[1897]: ============== UMBREL ================
May 21 10:56:57 umbrel umbrel startup[1897]: ======================================
May 21 10:56:57 umbrel umbrel startup[1897]: Setting environment variables…
May 21 10:56:57 umbrel umbrel startup[1897]: Starting karen…
May 21 10:56:57 umbrel umbrel startup[1897]: Starting backup monitor…
May 21 10:56:57 umbrel umbrel startup[1897]: Starting decoy backup trigger…
May 21 10:56:57 umbrel umbrel startup[1897]: Starting Docker services…
May 21 10:57:00 umbrel umbrel startup[1897]: Starting dashboard …
May 21 10:57:00 umbrel umbrel startup[1897]: Starting tor …
May 21 10:57:00 umbrel umbrel startup[1897]: Starting electrs …
May 21 10:57:02 umbrel umbrel startup[1897]: Starting dashboard … done
May 21 10:57:02 umbrel umbrel startup[1897]: Starting electrs … done
May 21 10:57:02 umbrel umbrel startup[1897]: Starting tor … done
May 21 10:57:02 umbrel umbrel startup[1897]: Starting manager …
May 21 10:57:04 umbrel umbrel startup[1897]: Starting manager … done
May 21 10:57:04 umbrel umbrel startup[1897]: a09517eca77b_lnd is up-to-date
May 21 10:57:04 umbrel umbrel startup[1897]: Starting nginx …
May 21 10:57:06 umbrel umbrel startup[1897]: Starting nginx … done
May 21 10:57:06 umbrel umbrel startup[1897]: Starting bitcoin …
May 21 10:57:08 umbrel umbrel startup[1897]: Starting bitcoin … done
May 21 10:57:08 umbrel umbrel startup[1897]: Starting neutrino-switcher …
May 21 10:57:08 umbrel umbrel startup[1897]: Recreating middleware …
May 21 10:57:11 umbrel umbrel startup[1897]: Starting neutrino-switcher … done
May 21 10:57:12 umbrel umbrel startup[1897]: Recreating middleware … done
May 21 10:57:12 umbrel umbrel startup[1897]: Starting installed apps…
May 21 10:57:12 umbrel umbrel startup[1897]: Umbrel is now accessible at
May 21 10:57:12 umbrel umbrel startup[1897]: http://umbrel.local
May 21 10:57:12 umbrel umbrel startup[1897]: http://192.168.100.54
May 21 10:57:12 umbrel systemd[1]: Started Umbrel Startup Service.
External storage service logs
– Logs begin at Mon 2021-05-03 13:28:10 UTC, end at Fri 2021-05-21 12:08:40 UTC. –
May 03 13:28:13 umbrel systemd[1]: Starting External Storage Mounter…
May 03 13:28:13 umbrel external storage mounter[373]: Running external storage mount script…
May 03 13:28:14 umbrel external storage mounter[373]: Found device “CT2000MX 500SSD1”
May 03 13:28:14 umbrel external storage mounter[373]: Blacklisting USB device IDs against UAS driver…
May 03 13:28:14 umbrel external storage mounter[373]: Rebinding USB drivers…
May 03 13:28:14 umbrel external storage mounter[373]: Checking USB devices are back…
May 03 13:28:14 umbrel external storage mounter[373]: Waiting for USB devices…
May 03 13:28:15 umbrel external storage mounter[373]: Waiting for USB devices…
May 03 13:28:16 umbrel external storage mounter[373]: Checking if the device is ext4…
May 03 13:28:18 umbrel external storage mounter[373]: Yes, it is ext4
May 03 13:28:19 umbrel external storage mounter[373]: Checking if device contains an Umbrel install…
May 03 13:28:19 umbrel external storage mounter[373]: Yes, it contains an Umbrel install
May 03 13:28:19 umbrel external storage mounter[373]: Bind mounting external storage over local Umbrel installation…
May 03 13:28:19 umbrel external storage mounter[373]: Bind mounting external storage over local Docker data dir…
May 03 13:28:19 umbrel external storage mounter[373]: Bind mounting external storage to /swap
May 03 13:28:19 umbrel external storage mounter[373]: Bind mounting SD card root at /sd-card…
May 03 13:28:19 umbrel external storage mounter[373]: Checking Umbrel root is now on external storage…
May 03 13:28:20 umbrel external storage mounter[373]: Checking /var/lib/docker is now on external storage…
May 03 13:28:20 umbrel external storage mounter[373]: Checking /swap is now on external storage…
May 03 13:28:20 umbrel external storage mounter[373]: Setting up swapfile
May 03 13:28:21 umbrel external storage mounter[373]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
May 03 13:28:21 umbrel external storage mounter[373]: no label, UUID=9321592f-9807-40cc-ae71-012835d6ff43
May 03 13:28:21 umbrel external storage mounter[373]: Checking SD Card root is bind mounted at /sd-root…
May 03 13:28:21 umbrel external storage mounter[373]: Starting external drive mount monitor…
May 03 13:28:21 umbrel external storage mounter[373]: Mount script completed successfully!
May 03 13:28:21 umbrel systemd[1]: Started External Storage Mounter.
May 21 10:56:57 umbrel systemd[1]: Starting External Storage SDcard Updater…
May 21 10:56:57 umbrel external storage updater[1813]: Checking if SD card Umbrel is newer than external storage…
May 21 10:56:57 umbrel external storage updater[1813]: No, SD version is not newer, exiting.
May 21 10:56:57 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
middleware Up About an hour
manager Up About an hour
neutrino-switcher Up About an hour
bitcoin Up About an hour
a09517eca77b_lnd Restarting (1) 15 seconds ago
nginx Up About an hour
tor Up About an hour
dashboard Up About an hour
electrs Up About an hour
Bitcoin Core logs
Attaching to bitcoin
bitcoin | 2021-05-21T12:08:22Z Pre-allocating up to position 0x8000000 in blk00542.dat
bitcoin | 2021-05-21T12:08:27Z UpdateTip: new best=00000000000000000084d16b14114d42d168edde45720ad1850098744b2c3466 height=415641 version=0x20000001 log2_work=84.806642 tx=134828317 date=‘2016-06-10T09:40:28Z’ progress=0.209409 cache=157.5MiB(1017836txo)
bitcoin | 2021-05-21T12:08:28Z UpdateTip: new best=000000000000000000c82d6fc1354c3fc13f241f3459b7b7c1856d79d0581c7d height=415642 version=0x20000001 log2_work=84.806678 tx=134830727 date=‘2016-06-10T09:57:41Z’ progress=0.209412 cache=158.2MiB(1023238txo)
bitcoin | 2021-05-21T12:08:28Z UpdateTip: new best=00000000000000000335c6ef81f699138811a494aaecebc4d833f1b96b6ade56 height=415643 version=0x20000001 log2_work=84.806713 tx=134833570 date=‘2016-06-10T10:29:33Z’ progress=0.209417 cache=158.6MiB(1026453txo)
bitcoin | 2021-05-21T12:08:29Z UpdateTip: new best=000000000000000001d319025f30ce25093f81c6b663b581f231653c4b43405c height=415644 version=0x20000001 log2_work=84.806749 tx=134835327 date=‘2016-06-10T10:31:12Z’ progress=0.209420 cache=159.1MiB(1030551txo)
bitcoin | 2021-05-21T12:08:29Z UpdateTip: new best=000000000000000001f11c5db39f6e4c18072acaca3e42383ded801dea60867a height=415645 version=0x20000001 log2_work=84.806785 tx=134835328 date=‘2016-06-10T10:31:34Z’ progress=0.209420 cache=159.1MiB(1030552txo)
bitcoin | 2021-05-21T12:08:30Z Pre-allocating up to position 0x700000 in rev00540.dat
bitcoin | 2021-05-21T12:08:30Z UpdateTip: new best=0000000000000000018c2f4febaa5faf4e9c0854115163635e9f3c9493802873 height=415646 version=0x20000001 log2_work=84.806821 tx=134836509 date=‘2016-06-10T10:34:15Z’ progress=0.209421 cache=159.5MiB(1033955txo)
bitcoin | 2021-05-21T12:08:31Z UpdateTip: new best=000000000000000003472b118c0ce1d6932e04ce3284ecc941ec5d91c7056b47 height=415647 version=0x20000001 log2_work=84.806857 tx=134837327 date=‘2016-06-10T10:38:44Z’ progress=0.209423 cache=159.7MiB(1035698txo)
bitcoin | 2021-05-21T12:08:33Z UpdateTip: new best=000000000000000005002bc32aa63f59fd55ae2d7ab5c9743e40d6b9475e3c28 height=415648 version=0x20000001 log2_work=84.806893 tx=134838199 date=‘2016-06-10T10:41:56Z’ progress=0.209424 cache=160.1MiB(1038790txo)
bitcoin | 2021-05-21T12:08:33Z UpdateTip: new best=000000000000000005693c5285491255d028c0682a4fcd6f95da00f970cf2e84 height=415649 version=0x20000001 log2_work=84.806929 tx=134838428 date=‘2016-06-10T10:42:57Z’ progress=0.209424 cache=160.3MiB(1040150txo)
bitcoin | 2021-05-21T12:08:33Z UpdateTip: new best=0000000000000000016d1fd411e2151a58ae77f50effb21a3cc45891d0eb3e51 height=415650 version=0x30000000 log2_work=84.806965 tx=134839818 date=‘2016-06-10T10:51:41Z’ progress=0.209427 cache=160.4MiB(1041633txo)
bitcoin | 2021-05-21T12:08:34Z UpdateTip: new best=000000000000000002d269c1ad6c7867a75bde51d0ca205adac1387e18c45ce8 height=415651 version=0x20000001 log2_work=84.807001 tx=134842361 date=‘2016-06-10T11:05:26Z’ progress=0.209431 cache=160.8MiB(1044240txo)
bitcoin | 2021-05-21T12:08:34Z UpdateTip: new best=0000000000000000031c7c9680b276f72893e0ae588a9c2aa9851cfced07af42 height=415652 version=0x20000001 log2_work=84.807037 tx=134845017 date=‘2016-06-10T11:24:18Z’ progress=0.209435 cache=161.1MiB(1047023txo)
bitcoin | 2021-05-21T12:08:35Z UpdateTip: new best=000000000000000003ba4a8ccf8e2f2f753c0752c56261340fd90648bb9a7c96 height=415653 version=0x20000001 log2_work=84.807072 tx=134846098 date=‘2016-06-10T11:25:56Z’ progress=0.209436 cache=161.2MiB(1047763txo)
bitcoin | 2021-05-21T12:08:35Z UpdateTip: new best=000000000000000004d634bd9d07deff7093e873b94e8649d336c1020a5144f1 height=415654 version=0x20000001 log2_work=84.807108 tx=134846257 date=‘2016-06-10T11:26:20Z’ progress=0.209437 cache=161.2MiB(1047937txo)
bitcoin | 2021-05-21T12:08:35Z UpdateTip: new best=000000000000000005808c7c026e36b2195427b9198d9df248a16c0d9becd275 height=415655 version=0x20000001 log2_work=84.807144 tx=134846511 date=‘2016-06-10T11:27:55Z’ progress=0.209437 cache=161.2MiB(1048099txo)
bitcoin | 2021-05-21T12:08:36Z UpdateTip: new best=000000000000000001d4568144f28d85e5456f3addb08fb29bf4299bdba5cd33 height=415656 version=0x20000001 log2_work=84.807180 tx=134849309 date=‘2016-06-10T11:46:03Z’ progress=0.209441 cache=161.6MiB(1051314txo)
bitcoin | 2021-05-21T12:08:36Z UpdateTip: new best=00000000000000000122a6b1b351d70d61ba536a6a4a55fdbd653f99fea86d32 height=415657 version=0x20000001 log2_work=84.807216 tx=134850970 date=‘2016-06-10T11:53:12Z’ progress=0.209444 cache=161.9MiB(1053308txo)
bitcoin | 2021-05-21T12:08:36Z Pre-allocating up to position 0x800000 in rev00540.dat
bitcoin | 2021-05-21T12:08:36Z UpdateTip: new best=000000000000000003c613b77bee8862f2df07d6d943dcebc8d41cf3086f6c8b height=415658 version=0x20000001 log2_work=84.807252 tx=134853997 date=‘2016-06-10T12:18:40Z’ progress=0.209449 cache=162.3MiB(1056582txo)
bitcoin | 2021-05-21T12:08:37Z Leaving block file 542: CBlockFileInfo(blocks=154, size=134153881, heights=415625…416132, time=2016-06-10…2016-06-13)
bitcoin | 2021-05-21T12:08:37Z Pre-allocating up to position 0x1000000 in blk00543.dat
bitcoin | 2021-05-21T12:08:38Z Pre-allocating up to position 0x2000000 in blk00543.dat
bitcoin | 2021-05-21T12:08:40Z Pre-allocating up to position 0x3000000 in blk00543.dat
bitcoin | 2021-05-21T12:08:47Z Pre-allocating up to position 0x4000000 in blk00543.dat
bitcoin | 2021-05-21T12:08:48Z Pre-allocating up to position 0x100000 in rev00543.dat
bitcoin | 2021-05-21T12:08:48Z UpdateTip: new best=0000000000000000010dccd2dacca2d6030b537daea8161a7cfe77ed3421b8c1 height=415659 version=0x20000001 log2_work=84.807288 tx=134856834 date=‘2016-06-10T13:00:03Z’ progress=0.209453 cache=162.7MiB(1060213txo)
bitcoin | 2021-05-21T12:08:49Z UpdateTip: new best=000000000000000001f11819e60de72ab5269a67200b96e4b669972f5a570be5 height=415660 version=0x20000001 log2_work=84.807324 tx=134859152 date=‘2016-06-10T13:02:31Z’ progress=0.209457 cache=163.0MiB(1062855txo)
bitcoin | 2021-05-21T12:08:49Z UpdateTip: new best=00000000000000000175d41ae99294853297e4fe1aed7f7db2fd09b6dc2818dd height=415661 version=0x20000001 log2_work=84.807360 tx=134861571 date=‘2016-06-10T13:12:11Z’ progress=0.209460 cache=163.3MiB(1065191txo)
LND logs
Attaching to a09517eca77b_lnd
a09517eca77b_lnd | 2021-05-21 12:06:25.202 [INF] LTND: Version: 0.12.1-beta commit=v0.12.1-beta, build=production, logging=default, debuglevel=info
a09517eca77b_lnd | 2021-05-21 12:06:25.203 [INF] LTND: Active chain: Bitcoin (network=mainnet)
a09517eca77b_lnd | 2021-05-21 12:06:25.207 [INF] LTND: Opening the main database, this might take a few minutes…
a09517eca77b_lnd | 2021-05-21 12:06:25.207 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
a09517eca77b_lnd | 2021-05-21 12:06:25.213 [INF] CHDB: Checking for schema update: latest_version=20, db_version=20
a09517eca77b_lnd | 2021-05-21 12:06:25.214 [INF] LTND: Database now open (time_to_open=6.587388ms)!
a09517eca77b_lnd | 2021-05-21 12:06:25.481 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
a09517eca77b_lnd | 2021-05-21 12:06:25.482 [INF] LTND: Shutdown complete
a09517eca77b_lnd |
a09517eca77b_lnd | unable to initialize neutrino backend: unable to create neutrino light client: EOF
a09517eca77b_lnd | 2021-05-21 12:07:28.457 [INF] LTND: Version: 0.12.1-beta commit=v0.12.1-beta, build=production, logging=default, debuglevel=info
a09517eca77b_lnd | 2021-05-21 12:07:28.458 [INF] LTND: Active chain: Bitcoin (network=mainnet)
a09517eca77b_lnd | 2021-05-21 12:07:28.458 [INF] LTND: Opening the main database, this might take a few minutes…
a09517eca77b_lnd | 2021-05-21 12:07:28.458 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
a09517eca77b_lnd | 2021-05-21 12:07:28.462 [INF] CHDB: Checking for schema update: latest_version=20, db_version=20
a09517eca77b_lnd | 2021-05-21 12:07:28.462 [INF] LTND: Database now open (time_to_open=4.177836ms)!
a09517eca77b_lnd | 2021-05-21 12:07:28.713 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
a09517eca77b_lnd | 2021-05-21 12:07:28.713 [INF] LTND: Shutdown complete
a09517eca77b_lnd |
a09517eca77b_lnd | 2021-05-21 12:08:31.628 [INF] LTND: Version: 0.12.1-beta commit=v0.12.1-beta, build=production, logging=default, debuglevel=info
a09517eca77b_lnd | 2021-05-21 12:08:31.629 [INF] LTND: Active chain: Bitcoin (network=mainnet)
a09517eca77b_lnd | 2021-05-21 12:08:31.630 [INF] LTND: Opening the main database, this might take a few minutes…
a09517eca77b_lnd | 2021-05-21 12:08:31.630 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
a09517eca77b_lnd | 2021-05-21 12:08:31.641 [INF] CHDB: Checking for schema update: latest_version=20, db_version=20
a09517eca77b_lnd | 2021-05-21 12:08:31.642 [INF] LTND: Database now open (time_to_open=12.434919ms)!
a09517eca77b_lnd | 2021-05-21 12:08:31.764 [ERR] LTND: unable to initialize neutrino backend: unable to create neutrino light client: EOF
a09517eca77b_lnd | 2021-05-21 12:08:31.764 [INF] LTND: Shutdown complete
a09517eca77b_lnd |
Tor logs
Attaching to tor
tor | May 21 10:57:02.798 [notice] Read configuration file “/etc/tor/torrc”.
tor | May 21 10:57:02.803 [warn] You have a ControlPort set to accept connections from a non-local address. This means that programs not running on your computer can reconfigure your Tor. That’s pretty bad, since the controller protocol isn’t encrypted! Maybe you should just listen on 127.0.0.1 and use a tool like stunnel or ssh to encrypt remote connections to your control port.
tor | May 21 10:57:02.865 [notice] You configured a non-loopback address ‘10.21.21.11:9050’ for SocksPort. This allows everybody on your local network to use your machine as a proxy. Make sure this is what you wanted.
tor | May 21 10:57:02.865 [warn] You have a ControlPort set to accept connections from a non-local address. This means that programs not running on your computer can reconfigure your Tor. That’s pretty bad, since the controller protocol isn’t encrypted! Maybe you should just listen on 127.0.0.1 and use a tool like stunnel or ssh to encrypt remote connections to your control port.
tor | May 21 10:57:02.867 [notice] Opening Socks listener on 10.21.21.11:9050
tor | May 21 10:57:02.867 [notice] Opened Socks listener connection (ready) on 10.21.21.11:9050
tor | May 21 10:57:02.867 [notice] Opening Control listener on 10.21.21.11:29051
tor | May 21 10:57:02.867 [notice] Opened Control listener connection (ready) on 10.21.21.11:29051
tor | May 21 10:57:03.000 [notice] Bootstrapped 0% (starting): Starting
tor | May 21 10:57:03.000 [notice] Starting with guard context “default”
tor | May 21 10:57:04.000 [notice] Bootstrapped 5% (conn): Connecting to a relay
tor | May 21 10:57:05.000 [notice] Bootstrapped 10% (conn_done): Connected to a relay
tor | May 21 10:57:05.000 [notice] Bootstrapped 14% (handshake): Handshaking with a relay
tor | May 21 10:57:05.000 [notice] Bootstrapped 15% (handshake_done): Handshake with a relay done
tor | May 21 10:57:05.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
tor | May 21 10:57:05.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
tor | May 21 10:57:05.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
tor | May 21 10:57:06.000 [notice] Bootstrapped 100% (done): Done
tor | May 21 10:57:15.000 [notice] Guard Unnamed ($8DFCA3E1B22312330149D1BF24365534B93FA384) is failing more circuits than usual. Most likely this means the Tor network is overloaded. Success counts are 149/214. Use counts are 132/132. 151 circuits completed, 0 were unusable, 2 collapsed, and 1 timed out. For reference, your timeout cutoff is 60 seconds.
tor | May 21 10:57:15.000 [warn] Guard Unnamed ($8DFCA3E1B22312330149D1BF24365534B93FA384) is failing a very large amount of circuits. Most likely this means the Tor network is overloaded, but it could also mean an attack against you or potentially the guard itself. Success counts are 149/299. Use counts are 132/132. 151 circuits completed, 0 were unusable, 2 collapsed, and 1 timed out. For reference, your timeout cutoff is 60 seconds.
tor | May 21 10:57:28.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 564 buildtimes.
tor | May 21 10:57:30.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 172 buildtimes.
tor | May 21 10:57:41.000 [notice] Your network connection speed appears to have changed. Resetting timeout to 60s after 18 timeouts and 101 buildtimes.
tor | May 21 11:00:46.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | May 21 11:01:39.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | May 21 11:02:16.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | May 21 11:03:32.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | May 21 11:17:00.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | May 21 11:44:28.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
tor | May 21 11:45:06.000 [notice] Have tried resolving or connecting to address ‘[scrubbed]’ at 3 different places. Giving up.
==== Result ====
The temperature of your Raspberry Pi is too high. We recommend either using a case that lowers the temperature of your Pi or a case with a builtin fan.
