[Feature Request] Please add the option to function as a Tor-relay (non-exit node)
As the lightning network grows so does the use and strain of the TOR network. (https://metrics.torproject.org/hidserv-rend-relayed-cells.html)
To support the Tor network, it would be nice if the Umbrel node would to be able to function as a relay-node (non-exit). Because the Umbrel node already uses the tor client only a change in config and some supporting documentation would suffice.
It would be a more advanced user option because of the requirement to change some settings in the router/firewall (NAT forwards).
This would support the Tor network a lot!
+1 :point_up_2:
Does anyone know if simple torrent uses the tor connection to download?
