Hi there! Apologies if this is a dumb question, I’m a bit of a novice when it comes to SSH commands and such. I attempted to update UmbrelOS to 1.5 and the update “hung”, becoming unresponsive. I have it installed on a Dell laptop I wasn’t using for anything else.
I can still access the shell on the laptop, but any attempts to connect to umbrel.local time out. I perused the forum for similar situations but ultimately wasn’t able to find a solution. I attempted things like sudo apt-get update && sudo apt upgrade -y –fix-missing to no avail– updates hang with a bunch of Failed to fetch… returns and ultimate returns Some index files failed to download. They have been ignored, or old ones used instead.
I also attempted to remove the update in progress? I tried: rm -f ~/umbrel/statuses/update-in-progress && sudo rebootand while the shell rebooted on the device, I still can’t access umbrel.local
Am I cooked? How do I fix this? I feel like such a n00b, I don’t even know how to pull log files. Any and all help would be greatly, greatly appreciated.
