Having the same issues as others have stated.
**Error: No external drive found**
Please connect an external drive (at least 1TB) to a USB 3.0 port (blue color) on your Raspberry Pi and restart your Umbrel.
I’m using the official Raspberry Pi 4 power supply, so I don’t think power should be an issue.
I’ve also plugged my SSD into my computer and confirmed it recognized and that the blue light on it turns on, so I don’t think the SSD is the issue.
I’ve also plugged my USB phone charger into the Raspberry Pi USB slot and it starts charging, so I don’t think the USB slot is the issue.
Node had been running totally fine for almost a year. The only notable change was updating to Umbrel 0.4.18 relatively recently. The node was running fine after the update.
Here are the ~/umbrel/scripts/debug logs:
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
cam-Mac:~ cam$ ssh -t umbrel@umbrel.local
umbrel@umbrel.local's password:
Linux umbrel 5.10.17-v8+ #1403 SMP PREEMPT Mon Feb 22 11:37:54 GMT 2021 aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Oct 4 01:25:50 2022 from 192.168.0.14
umbrel@umbrel:~ $ ~/umbrel/scripts/debug
0.4.18
Flashed OS version
v0.3.10
Raspberry Pi Model
Revision : d03114
Serial : 100000004cec25f9
Firmware
Feb 25 2021 12:10:40
Copyright (c) 2012 Broadcom
version 564e5f9b852b23a330b1764bcf0b2d022a20afd0 (clean) (release) (start)
Temperature
temp=41.8'C
Throttling
throttled=0x0
Mem: 7.8G 164M 7.4G 8.0M 232M 7.5G
Swap: 0B 0B 0B
total: 2.1%
system: 2.1%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
tail: cannot open '/home/umbrel/umbrel/scripts/../logs/memory-monitor.log' for reading: No such file or directory
/dev/root 14G 2.8G 11G 21% /
Startup service logs
-- Logs begin at Tue 2022-10-04 01:29:22 UTC, end at Tue 2022-10-04 01:45:52 UTC. --
Oct 04 01:44:45 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Oct 04 01:44:45 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result 'dependency'.
External storage service logs
Oct 04 01:43:39 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:43:44 umbrel external storage mounter[516]: No block devices found
Oct 04 01:43:44 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:43:49 umbrel external storage mounter[516]: No block devices found
Oct 04 01:43:49 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:43:54 umbrel external storage mounter[516]: No block devices found
Oct 04 01:43:54 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:43:59 umbrel external storage mounter[516]: No block devices found
Oct 04 01:43:59 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:04 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:04 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:09 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:09 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:15 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:15 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:20 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:20 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:25 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:25 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:30 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:30 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:35 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:35 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:40 umbrel external storage mounter[516]: No block devices found
Oct 04 01:44:40 umbrel external storage mounter[516]: Waiting for 5 seconds before checking again...
Oct 04 01:44:45 umbrel external storage mounter[516]: No block devices found in 20 tries...
Oct 04 01:44:45 umbrel external storage mounter[516]: Exiting mount script without doing anything
Oct 04 01:44:45 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Oct 04 01:44:45 umbrel systemd[1]: umbrel-external-storage.service: Failed with result 'exit-code'.
Oct 04 01:44:45 umbrel systemd[1]: Failed to start External Storage Mounter.
Oct 04 01:44:45 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Oct 04 01:44:45 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result 'dependency'.
Karen logs
tail: cannot open 'logs/karen.log' for reading: No such file or directory
Docker containers
NAMES STATUS
Umbrel logs
ERROR: The Compose file './docker-compose.yml' is invalid because:
services.lnd.ports value ['9735:9735', ':', ':'] has non-unique elements
Bitcoin Core logs
LND logs
electrs logs
Tor logs
==== Result ====
You have either no external drive connected to your Raspberry Pi or the drive is not being detected.
Please shutdown your Raspberry Pi ('sudo shutdown'), then plug the SSD into the other USB3 port.
After you've finished that, boot your Raspberry Pi back up. If it still still doesn't work,
you can contact us on Telegram (t.me/getumbrel) and share the output of this script.
umbrel@umbrel:~ $
