I keep getting an error when trying to change my alias for my node. I’m running a Raspberry pi4 and following instructions found on this network.
I start by logging into my command prompt using ssh -t umbrel@umbrel.local
I can enter my password and it brings up umbrel@umbrel: ~ $, where I enter command sudo nano umbrel/lnd/lnd.conf and it again asks for my password. When I reenter my password and press enter I get an error message. Directory 'umbrel/lnd does not exist.
I’m new to the space and not sure if I’m missing something or need a different command. I appreciate any feedback.
Hey @PizzaPaisan, sorry that you’ve run into this issue.
With new versions of Umbrel the lnd.conf file is located in :
~/umbrel/app-data/lightning/data/lnd/
you can edit the file using :
sudo nano ~/umbrel/app-data/lightning/data/lnd/lnd.conf
you can then add in the [Application Options] block.
alias=SOMENAME
I hope this solves your issue !
Thank you very much for the quick response and info. I was able to make the change with success!
