Error: System service failed: "Structure needs cleaning"
Can’t access my Umbrel anymore.
I’m not sure, but i think it might be a hardware failure.
Could someone please look over my log file:
0.5.0
Flashed OS version
v0.4.18
Raspberry Pi Model
Revision : d03115
Serial : 10000000ee0b6794
Firmware
Dec 1 2021 15:01:54
Copyright © 2012 Broadcom
Temperature
temp=34.0’C
Throttling
throttled=0x0
Mem: 7.8G 133M 7.5G 8.0M 216M 7.6G
Swap: 0B 0B 0B
total: 1.7%
system: 1.7%
tor: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
/dev/root 29G 3.3G 25G 12% /
Startup service logs
– Logs begin at Fri 2022-07-01 04:45:36 UTC, end at Fri 2022-07-01 04:56:20 UTC. –
Jul 01 04:45:44 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Jul 01 04:45:44 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Jul 01 04:45:41 umbrel systemd[1]: Starting External Storage Mounter…
Jul 01 04:45:41 umbrel external storage mounter[488]: Running external storage mount script…
Jul 01 04:45:41 umbrel external storage mounter[488]: Found device “TOSHIBA EXTERNAL_USB”
Jul 01 04:45:41 umbrel external storage mounter[488]: Blacklisting USB device IDs against UAS driver…
Jul 01 04:45:41 umbrel external storage mounter[488]: Rebinding USB drivers…
Jul 01 04:45:41 umbrel external storage mounter[488]: Checking USB devices are back…
Jul 01 04:45:41 umbrel external storage mounter[488]: Waiting for USB devices…
Jul 01 04:45:42 umbrel external storage mounter[488]: Waiting for USB devices…
Jul 01 04:45:43 umbrel external storage mounter[488]: Waiting for USB devices…
Jul 01 04:45:44 umbrel external storage mounter[488]: Checking if the device is ext4…
Jul 01 04:45:44 umbrel external storage mounter[488]: Yes, it is ext4
Jul 01 04:45:44 umbrel external storage mounter[488]: mount: /mnt/data: mount(2) system call failed: Structure needs cleaning.
Jul 01 04:45:44 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=32/n/a
Jul 01 04:45:44 umbrel systemd[1]: umbrel-external-storage.service: Failed with result ‘exit-code’.
Jul 01 04:45:44 umbrel systemd[1]: Failed to start External Storage Mounter.
Jul 01 04:45:44 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Jul 01 04:45:44 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result ‘dependency’.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Tor logs
==== Result ====
Under “External Storage Service Logs” it says: “mount: /mnt/data: mount(2) system call failed: Structure needs cleaning.”
I switched the cables and tried different ports but that didn’t solve my issues.
What would you recommend me to do next?
I’m using a Raspberry PI 4 (8GB) and a Toshiba 1 TB HDD Drive. Is the Harddrive not compatible?
Any help is highly appreciated. I just want to avoid re-formatting the HDD and downloading the blockchain again (took me almost a month this time due to the TOR issues)
