Running Umbrel on The Bitcoin Machine.
Moved homes so I had to unplug my node. When I plug into new home, I get this error:
Logs are below…
0.5.3
Flashed OS version
v0.4.4
Raspberry Pi Model
Revision : d03114
Serial : 100000007ffb3163
Firmware
Sep 28 2021 11:27:35
Copyright (c) 2012 Broadcom
version 778b6a4f3c7d8d48bb63c02c47bcfbac79417bea (clean) (release) (start)
Temperature
temp=46.7’C
Throttling
throttled=0x0
Mem: 7.8G 244M 7.2G 8.0M 416M 7.4G
Swap: 4.1G 0B 4.1G
ƒtotal: 3.1%
system: 3.1%
snort: 0%
samourai-server: 0%
mempool: 0%
lightning: 0%
electrs: 0%
btcpay-server: 0%
bitcoin: 0%
Memory monitor logs
2019-02-14 02:12:47 Memory monitor running!
2019-02-14 02:12:17 Memory monitor running!
2019-02-14 02:12:32 Memory monitor running!
2019-02-14 02:12:46 Memory monitor running!
2019-02-14 02:13:00 Memory monitor running!
2019-02-14 02:13:13 Memory monitor running!
2019-02-14 02:13:27 Memory monitor running!
2019-02-14 02:13:40 Memory monitor running!
2019-02-14 02:13:54 Memory monitor running!
2019-02-14 02:14:09 Memory monitor running!
/dev/root 29G 29G 0 100% /
/dev/sda1 916G 646G 224G 75% /home/umbrel/umbrel
Startup service logs
Feb 14 02:13:58 umbrel umbrel startup[6196]: ERROR: for tor_server Cannot start service tor_server: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 02:13:58 umbrel umbrel startup[6196]: ERROR: for dashboard Cannot start service dashboard: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 02:13:58 umbrel umbrel startup[6196]: ERROR: for manager Cannot start service manager: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 02:13:58 umbrel umbrel startup[6196]: ERROR: for tor_proxy Cannot start service tor_proxy: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 02:13:58 umbrel umbrel startup[6196]: ERROR: for auth Cannot start service auth: write /var/lib/containerd/io.containerd.metadata.v1.bolt/meta.db: no space left on device: unknown
Feb 14 02:13:58 umbrel umbrel startup[6196]: Encountered errors while bringing up the project.
Feb 14 02:13:58 umbrel umbrel startup[6196]: Failed to start containers
Feb 14 02:13:58 umbrel systemd[1]: umbrel-startup.service: Control process exited, code=exited, status=1/FAILURE
Feb 14 02:13:58 umbrel systemd[1]: umbrel-startup.service: Failed with result ‘exit-code’.
Feb 14 02:13:58 umbrel systemd[1]: Failed to start Umbrel Startup Service.
Feb 14 02:14:08 umbrel systemd[1]: umbrel-startup.service: Service RestartSec=10s expired, scheduling restart.
Feb 14 02:14:08 umbrel systemd[1]: umbrel-startup.service: Scheduled restart job, restart counter is at 8.
Feb 14 02:14:08 umbrel systemd[1]: Stopped Umbrel Startup Service.
Feb 14 02:14:08 umbrel systemd[1]: Starting Umbrel Startup Service…
Feb 14 02:14:09 umbrel umbrel startup[7638]: ======================================
Feb 14 02:14:09 umbrel umbrel startup[7638]: ============= STARTING ===============
Feb 14 02:14:09 umbrel umbrel startup[7638]: ============== UMBREL ================
Feb 14 02:14:09 umbrel umbrel startup[7638]: Setting environment variables…
Feb 14 02:14:09 umbrel umbrel startup[7638]: Starting karen…
Feb 14 02:14:09 umbrel umbrel startup[7638]: Starting status monitors…
Feb 14 02:14:09 umbrel umbrel startup[7638]: Starting memory monitor…
Feb 14 02:14:09 umbrel umbrel startup[7638]: Starting backup monitor…
Feb 14 02:14:09 umbrel umbrel startup[7638]: Starting decoy backup trigger…
Feb 14 02:14:09 umbrel umbrel startup[7638]: Starting Docker services…
Feb 14 02:14:11 umbrel umbrel startup[7638]: Starting manager …
Feb 14 02:14:11 umbrel umbrel startup[7638]: Starting auth …
Feb 14 02:14:11 umbrel umbrel startup[7638]: Starting tor_proxy …
Feb 14 02:14:11 umbrel umbrel startup[7638]: Starting tor_server …
Feb 14 02:14:11 umbrel umbrel startup[7638]: Starting dashboard …
External storage service logs
Feb 14 02:12:03 umbrel external storage mounter[522]: Checking USB devices are back…
Feb 14 02:12:03 umbrel external storage mounter[522]: Waiting for USB devices…
Feb 14 02:12:04 umbrel external storage mounter[522]: Waiting for USB devices…
Feb 14 02:12:05 umbrel external storage mounter[522]: Waiting for USB devices…
Feb 14 02:12:06 umbrel external storage mounter[522]: Checking if the device is ext4…
Feb 14 02:12:06 umbrel external storage mounter[522]: Yes, it is ext4
Feb 14 02:12:06 umbrel external storage mounter[522]: Checking filesystem for corruption…
Feb 14 02:12:06 umbrel external storage mounter[522]: e2fsck 1.44.5 (15-Dec-2018)
Feb 14 02:12:07 umbrel external storage mounter[522]: Superblock last mount time is in the future.
Feb 14 02:12:07 umbrel external storage mounter[522]: (by less than a day, probably due to the hardware clock being incorrectly set)
Feb 14 02:12:07 umbrel external storage mounter[522]: Superblock last write time is in the future.
Feb 14 02:12:07 umbrel external storage mounter[522]: umbrel: clean, 336636/61054976 files, 173297357/244190208 blocks
Feb 14 02:12:07 umbrel external storage mounter[522]: Mounting partition…
Feb 14 02:12:07 umbrel external storage mounter[522]: Checking if device contains an Umbrel install…
Feb 14 02:12:07 umbrel external storage mounter[522]: Yes, it contains an Umbrel install
Feb 14 02:12:07 umbrel external storage mounter[522]: Bind mounting external storage over local Umbrel installation…
Feb 14 02:12:07 umbrel external storage mounter[522]: Bind mounting external storage over local Docker data dir…
Feb 14 02:12:07 umbrel external storage mounter[522]: Bind mounting external storage to /swap
Feb 14 02:12:07 umbrel external storage mounter[522]: Bind mounting SD card root at /sd-card…
Feb 14 02:12:07 umbrel external storage mounter[522]: Checking Umbrel root is now on external storage…
Feb 14 02:12:08 umbrel external storage mounter[522]: Checking /var/lib/docker is now on external storage…
Feb 14 02:12:08 umbrel external storage mounter[522]: Checking /swap is now on external storage…
Feb 14 02:12:08 umbrel external storage mounter[522]: Setting up swapfile
Feb 14 02:12:08 umbrel external storage mounter[522]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Feb 14 02:12:08 umbrel external storage mounter[522]: no label, UUID=fb0f3fec-e42e-40cc-9b10-b011859dd707
Feb 14 02:12:08 umbrel external storage mounter[522]: Checking SD Card root is bind mounted at /sd-root…
Feb 14 02:12:08 umbrel external storage mounter[522]: Starting external drive mount monitor…
Feb 14 02:12:08 umbrel external storage mounter[522]: Mount script completed successfully!
Feb 14 02:12:08 umbrel systemd[1]: Started External Storage Mounter.
Feb 14 02:12:17 umbrel external storage updater[1061]: == Begin Update Script 01-run.sh ==
Feb 14 02:12:17 umbrel external storage updater[1061]: =======================================
Feb 14 02:12:17 umbrel external storage updater[1061]: =============== UPDATE ================
Feb 14 02:12:17 umbrel external storage updater[1061]: =========== Stage: Install ============
Feb 14 02:12:17 umbrel external storage updater[1061]: =============================================
Feb 14 02:12:17 umbrel external storage updater[1061]: Installing on Umbrel OS v0.4.4
Feb 14 02:12:17 umbrel external storage updater[1061]: ./01-run.sh: line 25: cannot create temp file for here-document: No space left on device
Feb 14 02:12:17 umbrel external storage updater[1061]: == End Update Script 01-run.sh ==
Feb 14 02:12:17 umbrel external storage updater[1061]: == Begin Update Script 02-run.sh ==
Feb 14 02:12:17 umbrel external storage updater[1061]: ========= Stage: Post-update ==========
Feb 14 02:12:17 umbrel external storage updater[1061]: == End Update Script 02-run.sh ==
Feb 14 02:12:17 umbrel external storage updater[1061]: == Begin Update Script 03-run.sh ==
Feb 14 02:12:17 umbrel external storage updater[1061]: =========== Stage: Success ============
Feb 14 02:12:17 umbrel external storage updater[1061]: Removing backup
Feb 14 02:12:17 umbrel external storage updater[1061]: ./03-run.sh: line 19: cannot create temp file for here-document: No space left on device
Feb 14 02:12:17 umbrel external storage updater[1061]: == End Update Script 03-run.sh ==
Feb 14 02:12:17 umbrel external storage updater[1061]: Deleting cloned repository
Feb 14 02:12:17 umbrel external storage updater[1061]: Removing lock
Feb 14 02:12:17 umbrel systemd[1]: Started External Storage SDcard Updater.
Karen logs
Docker containers
NAMES STATUS
Umbrel logs
Attaching to manager
Tor Proxy logs
Attaching to tor_proxy
App logs
bitcoin
Attaching to
btcpay-server
Attaching to
electrs
Attaching to
lightning
Attaching to
mempool
Attaching to
samourai-server
Attaching to
snort
Attaching to
==== Result ====
