At first I managed to connect to umbrel.local from the web UI. I created an account and installed the Bitcoin Node app. The blockchain syncing stopped at 4% and I shut down my raspberry. After starting it again, every attempt to connect to umbrel.local have failed. I can still ssh to umbrel though.
I am a noob with basically 0 technical background, but according to the debug log it seems that there is an issue with the format of my SSD (it says it is not ext4). I wiped out the disk using AOMEI partition assistant but this did not resolve the problem.
My HW setup:
Device: Raspberry Pi 4 Model B 8 GB RAM
Case: Argon One M.2: Aluminum Case
Storage drive: Samsung 980 PRO 1TB
Micro SD: SanDisk micro SDHC 32 GB Extreme Pro A1 UHS-I (V30)
Power supply: Raspberry Pi 4 USB-C official power supply
0.5.4
Flashed OS version
v0.5.4
Raspberry Pi Model
Revision : d03114
Serial : 10000000fb30698e
Firmware
May 9 2023 12:16:34
Copyright (c) 2012 Broadcom
Temperature
temp=36.0'C
Throttling
throttled=0x0
Mem: 7.8G 208M 7.0G 8.0M 633M 7.5G
Swap: 0B 0B 0B
total: 2.7%
system: 2.7%
bitcoin: 0%
Memory monitor logs
2023-09-04 12:11:16 Memory monitor running!
/dev/root 30G 28G 262M 100% /
Startup service logs
-- Logs begin at Wed 2023-09-06 09:51:30 UTC, end at Thu 2023-10-05 06:48:17 UTC. --
Sep 06 09:51:38 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Sep 06 09:51:38 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result 'dependency'.
External storage service logs
Sep 06 09:51:35 umbrel systemd[1]: Starting External Storage Mounter...
Sep 06 09:51:35 umbrel external storage mounter[486]: Running external storage mount script...
Sep 06 09:51:35 umbrel external storage mounter[486]: Found device "Argon Forty"
Sep 06 09:51:35 umbrel external storage mounter[486]: Blacklisting USB device IDs against UAS driver...
Sep 06 09:51:35 umbrel external storage mounter[486]: Rebinding USB drivers...
Sep 06 09:51:35 umbrel external storage mounter[486]: Checking USB devices are back...
Sep 06 09:51:35 umbrel external storage mounter[486]: Waiting for USB devices...
Sep 06 09:51:36 umbrel external storage mounter[486]: Waiting for USB devices...
Sep 06 09:51:37 umbrel external storage mounter[486]: Waiting for USB devices...
Sep 06 09:51:38 umbrel external storage mounter[486]: Checking if the device is ext4...
Sep 06 09:51:38 umbrel external storage mounter[486]: No, it's not ext4
Sep 06 09:51:38 umbrel external storage mounter[486]: Formatting device...
Sep 06 09:51:38 umbrel external storage mounter[486]: wipefs: error: /dev/sda: probing initialization failed: No medium found
Sep 06 09:51:38 umbrel systemd[1]: umbrel-external-storage.service: Main process exited, code=exited, status=1/FAILURE
Sep 06 09:51:38 umbrel systemd[1]: umbrel-external-storage.service: Failed with result 'exit-code'.
Sep 06 09:51:38 umbrel systemd[1]: Failed to start External Storage Mounter.
Sep 06 09:51:38 umbrel systemd[1]: Dependency failed for External Storage SDcard Updater.
Sep 06 09:51:38 umbrel systemd[1]: umbrel-external-storage-sdcard-update.service: Job umbrel-external-storage-sdcard-update.service/start failed with result 'dependency'.
Karen logs
Pulling server ... extracting (91.7%)
Pulling server ... extracting (95.7%)
Pulling server ... extracting (99.8%)
Pulling server ... extracting (100.0%)
Pulling server ... pull complete
Pulling server ... digest: sha256:edc0567efeadf30128...
Pulling server ... status: downloaded newer image fo...
Pulling server ... done
Starting app bitcoin...
Executing hook: /home/umbrel/umbrel/app-data/bitcoin/hooks/pre-start
Creating bitcoin_bitcoind_1 ...
Creating bitcoin_bitcoind_1 ... done
Creating bitcoin_tor_1 ...
Creating bitcoin_tor_1 ... done
App: bitcoin - Generating Tor Hidden Service...
App: bitcoin - Hidden service file created successfully!
bitcoin_tor_1 is up-to-date
bitcoin_bitcoind_1 is up-to-date
Creating bitcoin_i2pd_daemon_1 ...
Creating bitcoin_app_proxy_1 ...
Creating bitcoin_server_1 ...
Creating bitcoin_i2pd_daemon_1 ... done
Creating bitcoin_server_1 ... done
Creating bitcoin_app_proxy_1 ... done
Saving app bitcoin in DB...
Successfully installed app bitcoin
Got signal: backup
karen is getting triggered!
Deriving keys...
Creating backup...
Adding random padding...
1+0 records in
1+0 records out
9309 bytes (9.3 kB, 9.1 KiB) copied, 0.000385572 s, 24.1 MB/s
Creating encrypted tarball...
backup/
backup/.padding
gpg: directory '/root/.gnupg' created
gpg: keybox '/root/.gnupg/pubring.kbx' created
Uploading backup...
100 9998 100 146 100 9852 37 2545 0:00:03 0:00:03 --:--:-- 2582
{"message":"Successfully uploaded backup 1693850913125.tar.gz.pgp for backup ID c3b5d856934f74e7dcae799f287deb99db5304be23a96bf250427a7016037b10"}
====== Backup success =======
Docker containers
NAMES STATUS
Umbrel logs
Attaching to
Tor Proxy logs
Attaching to
App logs
bitcoin
Attaching to
==== Result ====
==== END =====
