Error: System service failed - Debug Log Posted
Any ideas on this debug? Background, I was partially synced and then i moved houses and got a new router. I couldn’t log on so i reflashed my SD card to the latest software with the intention of starting over.
I’m also not using a SSD, going with traditional hard drive to save money. I dont care about a few extra weeks of inital sync time
0.3.7
Umbrel OS version
v0.4.9
Raspberry Pi Model
Revision : c03112
Serial : 100000004f094317
Model : Raspberry Pi 4 Model B Rev 1.2
Firmware
Oct 29 2021 10:47:33
Copyright (c) 2012 Broadcom
version b8a114e5a9877e91ca8f26d1a5ce904b2ad3cf13 (clean) (release) (start)
Temperature
temp=38.9’C
Throttling
throttled=0x0
Startup service logs
– Logs begin at Sat 2021-12-11 17:20:27 UTC, end at Sat 2021-12-11 17:24:43 UTC. –
Dec 11 17:20:58 umbrel systemd[1]: Dependency failed for Umbrel Startup Service.
Dec 11 17:20:58 umbrel systemd[1]: umbrel-startup.service: Job umbrel-startup.service/start failed with result ‘dependency’.
External storage service logs
Dec 11 17:20:38 umbrel systemd[1]: Starting External Storage Mounter…
Dec 11 17:20:38 umbrel external storage mounter[484]: Running external storage mount script…
Dec 11 17:20:40 umbrel external storage mounter[484]: Found device “External USB3.0”
Dec 11 17:20:40 umbrel external storage mounter[484]: Blacklisting USB device IDs against UAS driver…
Dec 11 17:20:40 umbrel external storage mounter[484]: Rebinding USB drivers…
Dec 11 17:20:40 umbrel external storage mounter[484]: Checking USB devices are back…
Dec 11 17:20:40 umbrel external storage mounter[484]: Waiting for USB devices…
Dec 11 17:20:41 umbrel external storage mounter[484]: Waiting for USB devices…
Dec 11 17:20:42 umbrel external storage mounter[484]: Checking if the device is ext4…
Dec 11 17:20:44 umbrel external storage mounter[484]: Yes, it is ext4
Dec 11 17:20:45 umbrel external storage mounter[484]: Checking if device contains an Umbrel install…
Dec 11 17:20:45 umbrel external storage mounter[484]: Yes, it contains an Umbrel install
Dec 11 17:20:45 umbrel external storage mounter[484]: Bind mounting external storage over local Umbrel installation…
Dec 11 17:20:45 umbrel external storage mounter[484]: Bind mounting external storage over local Docker data dir…
Dec 11 17:20:45 umbrel external storage mounter[484]: Bind mounting external storage to /swap
Dec 11 17:20:45 umbrel external storage mounter[484]: Bind mounting SD card root at /sd-card…
Dec 11 17:20:45 umbrel external storage mounter[484]: Checking Umbrel root is now on external storage…
Dec 11 17:20:47 umbrel external storage mounter[484]: Checking /var/lib/docker is now on external storage…
Dec 11 17:20:47 umbrel external storage mounter[484]: Checking /swap is now on external storage…
Dec 11 17:20:47 umbrel external storage mounter[484]: Setting up swapfile
Dec 11 17:20:52 umbrel external storage mounter[484]: Setting up swapspace version 1, size = 4 GiB (4294963200 bytes)
Dec 11 17:20:52 umbrel external storage mounter[484]: no label, UUID=d295dc72-a5c4-4cb9-aedd-7110bfc778ac
Dec 11 17:20:52 umbrel external storage mounter[484]: Checking SD Card root is bind mounted at /sd-root…
Dec 11 17:20:52 umbrel external storage mounter[484]: Starting external drive mount monitor…
Dec 11 17:20:52 umbrel external storage mounter[484]: Mount script completed successfully!
Dec 11 17:20:52 umbrel systemd[1]: Started External Storage Mounter.
/dev/root 29G 3.0G 25G 11% /
devtmpfs 1.7G 0 1.7G 0% /dev
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 8.5M 1.9G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 30M 223M 12% /boot
/dev/sda1 916G 343G 527G 40% /mnt/data
tmpfs 380M 0 380M 0% /run/user/1000
Filename Type Size Used Priority
/swap/swapfile file 4194300 0 -2
Karen logs
backup/channel.backup
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0curl: (7) Can’t complete SOCKS5 connection to 0.0.0.0:0. (6)
====== Backup failed =======
Got signal: backup
karen is getting triggered!
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
1890 bytes (1.9 kB, 1.8 KiB) copied, 0.000281956 s, 6.7 MB/s
Creating encrypted tarball…
backup/
backup/.padding
Uploading backup…
Got signal: backup
Deriving keys…
Creating backup…
1+0 records in
1+0 records out
7568 bytes (7.6 kB, 7.4 KiB) copied, 0.000446434 s, 17.0 MB/s
backup/
backup/.padding
Uploading backup…
Docker containers
NAMES STATUS
Bitcoin Core logs
Attaching to
LND logs
Attaching to
Tor logs
Attaching to
==== Result ====
Please share the following links and paste it in the Umbrel Telegram group (Telegram: View @getumbrel) so we can help you with your problem.
I cleared the hard-drive out (deleted partitions and issue appears resolved). Node has restarted and is syncing to the blockchain
