- On what device / OS you are running Umbrel : Raspberry Pi 4
- How is your Umbrel connected to the Internet: Connected via Ethernet to a switch. Also tried direct into EERO directly, and no luck.
- What type of drive you are using: SSD
I am trying to acess it via my laptop which is wirelessly connected to the same network.
I can see “umbrel” on my network, so I would assume it is flashed onto the memory card correctly, but I can’t get it to connect vial umbrel.local or even by inputting the IP address directly.(I can see it on my eero). I am not really sure where to go from here. Any help is appreciated.
