Hello. I have the following issue:
When I open an address page in the Mempool app (eg http://{node_ip}:3006/address/{some_address}), I see a error:
Error loading address data.
*(failed to get block 00000000000000000012206336bbb49aca889479cae2877399756ad5798d4ffb)*
At the same time in the logs of electrs (sudo docker-compose logs -f electrs) I see the following, and then the container crashes:
electrs | [2022-03-08T13:00:53.451Z INFO electrs::electrum] your wallet uses less efficient method of querying electrs, consider contacting the developer of your wallet. Reason: blockchain.scripthash.get_balance called for unsubscribed scripthash: 43f626c7e6c22741e3160900776ba65f2526956c54779d193267fde55624adaf
electrs | [2022-03-08T13:00:53.624Z WARN electrs::thread] p2p_send thread failed: p2p failed to send
electrs | [2022-03-08T13:00:53.624Z WARN electrs::thread] because: Connection reset by peer (os error 104)
electrs | [2022-03-08T13:00:53.624Z WARN electrs::electrum] RPC blockchain.scripthash.get_balance failed: failed to get block 00000000000000000012206336bbb49aca889479cae2877399756ad5798d4ffb: receiving on an empty and disconnected channel
electrs | [2022-03-08T13:00:53.624Z INFO electrs::db] closing DB at /data/db/bitcoin
electrs | Error: electrs failed
electrs |
electrs | Caused by:
electrs | 0: sync failed
electrs | 1: sending on a disconnected channel
My setup
I’m running Umbrel on a regular PC, not a Pi. The OS is Debian 11. Nothing else is installed there besides the Umbrel. I followed the installation instructions here, but made one modification:
The OS is installed on an SSD, and the /umbrel directory is also located on the SSD, but I made /umbrel/bitcoin a soft link to a directory located on an HDD because I don’t have enough space on the SSD.
Umbrel version: 0.4.15
