Does UmbrelOS support the Raspberry Pi 5?
I’ve recently received my Raspberry Pi 5, and considering experimenting with UmbrelOS on it.
should be no reason why it’s not working. any linux system work. when the flash is not working try the manual install :slight_smile:
cheers
I don´t know how to do that, is there a step by step instruction somewhere or could you perhaps write a short guide? I think there are many who would appreciate it!
I´m running Citadel OS right now but it´s very buggy so I would rather switch to Umbrel and see if that works better on my Pi 5.
just install image from offical site
super easy super simple
it also gives you the steps for it
Wait 4 days.
The rollout of UmbrelOS 1.0 will then start.
i install umbrel 1.0 to RPi5 /to microsd/ with nvme hat and M.2 SSD and OS not recognize SSD… I view only SD card storage…
How i install Umbrel to RPI5 with NVME SSD ? When i install original Raspbian, NVME working fine.
False thread.
Please check this one:
There seems to be lots of issues with this new Umbrel 1.0. Stay away until they have things fixed. Or look elsewhere. Very disappointing.
Hi everyone, I‘m trying to install umbrel OS on my raspberrypie 5. when the prompt comes up: umbrel login:
Password:
I dont know how to get passed this!
Happy for any suggestions.
Thx
Are you starting fresh or moving from the pi4?
