Did not receive BTC from Anycoin on deposit (Lighting node)
Yesterday (approx 10:00 AM) I made a BTC transfer as a deposit to LND via its generated address (bc1q~yq) and until today the balance on the node is 0 sats.
I rebooted: LND , BTCND, UMBREL, no result.
What am I supposed to do?
THX
What fee did you choose? can you see the tx in the mempool?
Yes , in mempool is TX visible , but not added to the LND deposit.
You bought BTC on Anycoin, then you transferred the BTC to your BTC wallet address? Do you have pre-existing lightning channels?
I found this post for more information.
Yes, bought BTC from Anycoin and sent to BTC wallet in Lighting node via address generated in LND (bc1~),
I don’t have any channels, starting a new BTC node in UmbrelOS
Was the bc address to receive, generated on LND, for example? The sender needs to send the funds on chain for now since your node is new and has no routes on lightning. To be sure, try a small amount of sats and send them directly to a receive address on chain (not lightning address) and watch them pop in. You’ll know you’ve got the right address this way. Can you retrace your previous path to see what may have happened? If you sent to a lightning address, the funds could be hung for 24 hours, and returned. You may need to open a ticket with the wallet/sender and ask them to see if funds are hung, and to return them to you.
got it - i saw the post. looks like you are on the right track, and i can see where funds left your wallet. Since the one image was very faded, I couldn’t tell if it was the same wallet address on the LN from your wallet. As a side note, LN will generate a new receive BC address each time you send to it. As long as you know you sent it to the right address - it should arrive. Maybe confirm you are well connected and your BTC Node is running and in sync.
