Can't sign up with AFFiNE
Hi there,
I’m new to Umbrel and I’m using some apps since some days with no problem. It’s a very convenient and lovely product.
Unfortunately I’ve got one issue with AFFiNE. I installed the app, and tried to sign up for saving my work. When I’m using the form and put in the credential / default username, which I found in the description it says “failed to send email”…
I restarted and reinstalled the app several times.
The log has some errors, I guess the first one is that “the mailer service is not configured”.
I’m using a Raspberry Pi 4, with 4 GBs of RAM.
Did someone come through the same problem and know a solution?
Many kudos for help!
The current version is not working. I submitted the update for 0.16.3: Upgrade Affine to version 0.16.3 by Exileum · Pull Request #1408 · getumbrel/umbrel-apps · GitHub
Thanks for the reply! Everything seems to work fine with the updated version!
