Please keep in mind I am a complete novice with ubuntu and umbrel. I did run ~/umbrel/scripts/debug and among a bunch of other info I got this message:
permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/containers/json”: dial unix /var/run/docker.sock: connect: permission denied
Thanks for the response. I tried generating logs from the dashboard but generating logs just gets stuck in a loop. I ran sudo ~/umbrel/scripts/debug from terminal but I can’t paste it here because I get an error stating I can’t post more than 2 links.
