Umbrel Beta 1.2 WiFi Problems [help needed]
I flipped the switch and got Umbrel 1.2 Beta installed on my Pi5 and tried to configure WiFi. Here’s what happened:
  • Turned on switch for WiFi after successful download and reboot
  • Selected my 5Gh WiFi band, entered password
  • Umbrel did not connect, reverted back to the initial dialog for wifi setup
  • Tried again to connect to my 5Gh band, PW was accepted, connection made
  • Rebooted and accessed Umbrel by the new IP
  • Everything worked, so I tried to assign the old static IP to the new install
  • Could not connect via the old static IP, so I deleted that assignment in my router table
  • Tried connecting the Pi with both Ethernet and WiFi, both IP’s appear in my IP list
  • Still can’t connect to the machine via web, no response via ping either.
If anyone has some ideas, please let me know. It would suck to have to reinstall and download the entire bitcoin node again.
Thanks!
Installed 1.2 this morning with no issues connecting to WiFi using a Pi5.
