Can't Connect to Umbrel Home Hardware After Power Outage
Hello All,
I have a power outage last night and I’m not unable to connect to my Umbrel Home. I did a search and most of the trouble shooting tips say to plug in a monitor or SSH into the device however I am unable to do either.
The Umbrel Home doesn’t have a HDMI port or any port for a monitor and my router doesn’t see the device. I can’t ping umbrel.local and since the router doesn’t see the device I can’t get an IP for it.
I did unplug my external storage and held the power button to shut it off but even when it powers back on I can’t get to it.
Any help would be appreciated.
Thanks!
Yes, the Umbrel Home hardware was sold without an externally accessible HDMI port
. The device was designed as a “plug-and-play” appliance, intended to be managed entirely through a web browser, leading to the omission of display outputs in the official design.
However, the hardware does possess a functional HDMI port on the internal motherboard that was hidden from the user, which can be accessed by opening the casing.
Key Details Regarding the HDMI Port:
  • Purpose: Umbrel stated the internal HDMI port was intended for production line testing rather than consumer use, aiming to simplify the experience for non-technical users.
  • Functionality: While not exposed, the internal port is functional and can output a display, allowing for BIOS access and terminal usage.
  • Hidden Status: Several users reported needing to disassemble the Umbrel Home to locate the port, which was not documented by the company.
  • Newer Versions: The newer “Umbrel Pro” hardware lists HDMI 2.1 as a feature, indicating a change from the initial Umbrel Home, which lacked it.
The original Umbrel Home (Intel N5105) was marketed as having no need for a screen, keyboard, or mouse.
I suppose I could take it apart and see what that shows. Feels kind of extreme that I need to do that for a product that doesn’t come with it easily accessible.
That explains why my Umbrel Home wasn’t working when I returned from vacation.
I’m having the same problem.
After a week of AI and emails, this is as close as I get to a solution.
AI sent a link to this article because I can’t SSH on a PC.
Let me know if you get it fixed, I’ll do same.
I haven’t found a solution yet. I was waiting for support to respond to me, but it’s been about a week since I first put my ticket in and nothing. I didn’t want to open it up before I heard back in case it voided a warranty. I’m getting pretty close to just doing that though and see what’s going on.
I had something similar happen to my Umbrel server on my Intel NUC. It turned on, but I couldn’t ping it. I hooked up a monitor and keyboard, logged in with username “umbrel” and my password. Then I typed in “ip addr show” and “sudo reboot” followed by my password, and it worked after that.
I guess you could try typing this in without a monitor and see if it works…. If you want to see what your Umbrel Home hardware looks like in the inside (including the hidden HDMI port) check out this YouTube video: https://www.youtube.com/watch?v=kIGQEuutthk
I was able to fix it by following these instructions provided by support.
We’ll need to reinstall umbrelOS from a USB stick. Fair warning upfront: this will erase everything on the device, so any apps and data you had won’t be recoverable unless you have a backup. Here are the steps:
  1. On a computer, download the latest umbrelOS USB installer: https://download.umbrel.com/release/latest/umbrelos-amd64-usb-installer.iso
  2. Download and install Balena Etcher on that same computer: https://etcher.balena.io
  3. Plug in a USB stick (at least 4GB, it’ll be erased) and use Balena Etcher to flash the ISO to it.
  4. Once flashed, plug the USB stick into your Umbrel Home and power it on. It’ll boot from the USB and start the installer automatically.
  5. When it’s done, the device will shut itself down. Wait for it to fully power off (LED goes dark), then unplug the USB stick.
  6. Power the Umbrel Home back on. The first boot takes about 5 minutes, then head to umbrel.local in your browser to set it up fresh.
As it states I unfortunately did have to wipe the device to do this but at least it’s working now. I suppose I’ll just be a bit more forward thinking and actually use the backup feature to a separate drive this time.
