I tried installing and configuring OpenClaw yesterday on my Umbrel Home with 1.5 Umbrel OS. I may have tried to configure it with a model that was too large given all the other apps that I was running and available memory (16G). I went to stop some of the other apps in order to reclaim some memory and they would not stop (showed a spinner). At that point everything was frozen. I was not able to do a “sudo reboot” from the ssh shell.
I unplugged the power cable for 30s and plugged it back in. All the lights on the device show appropriately green. After waiting 1h I still could not access it use http://umbrel.local or ssh -t umbrel@umbrel.local. I can see that the device is on my home network with IP 10.0.0.51 and I can ping it. However, I cannot access it with http://10.0.0.51 or ssh -t umbrel@10.0.0.51 either. I tried lots of other AI suggestions, but nothing is working. After waiting another 24h I tried again, but still could not access it.
As I see it, my only 2 remaining options are to
- Take it apart and plug in a monitor and keyboard directly to the internal hidden html and USB ports in order to better diagnose what is going wrong.
- reflash OS from USB stick. This is something that I am very reluctant to do because it means loosing all of my data.
I will now try both of those last ditch options in that order unless I hear better suggestions.
