Can't connect to Samourai Whirlpool
device / OS: raspberry pi 4 8GB
connected to the Internet via WiFi
drive SSD
node 100% synced
I am following the Samourai Server steps and I achieve block 1 to connect to dojo but in the block 2 to connect to whirlpool gui I am stucked in step 6, when I click the connect button it outputs this error:
Connection failed: Could not connect to CLI (may take a few seconds to start…)
Any luck? I’m having the same problem.
The “may take a few seconds to start…” is a little misleading.
My experience has been that Tor takes a while so “seconds” can actually take a “minute.”
Is there an update on this?
I’ve got the same issue/PROBLEM!
I rebooted my node and was able to connect. :man_shrugging:
Hi, I have a same problem. Anyone know how to fix it?
Are you sure tor is running on your computer? You may need to open a terminal and type tor (if you’re on a mac).
I have the same problem. I have confirmed that Tor is running on my computer. I have also rebooted my Umbrel. None of this helps. A solution would be greatly appreciated!
Its kinda funny that nobody had a fix for this. This is stupid. Has anyone got this corrected? (can’t connect CLI)
Reinstalling/updating Tor solved this issue for me using windows 11. Also, make sure you have Tor open and connected before starting whirlpool.
