Can't acces my umbrel.local through wifi
Hey people,
I have a problem with my umbrel node.
First, it runs perfectly and is connected to a router through a ethernet cable.
The problem I have is that I can’t connect to my node using the WiFi from the same router while my node is connected to the same router with a cable.
Should this be possible? If so, can someone help me out
try to use the IP address of your node instead of umbrel.local
Think I’ve tried that already. But will try again.
Tx for the reply
Tried it, not working
From memory I had to edit the wpa_supplicant file with the command line interface to enable wifi. I am assuming that its turned off for a reason ? but don’t know for sure.
I used the method described here:
Subsequent umbrel updates have not disabled this.
Got it working now, tx
@Wv75
What did you change? I’ve noticed I can access umbrel locally just fine but when I try to reach it through a wifi-extender, I can access the main page, but I can’t access any apps (through various ports).
Read first these guides:
  1. How to setup a static IP for your node
  2. How to activate WiFi for your RPi - in Troubleshooting guide
