Cannot go back to a terminal window after closing it
I started reindexing the blockchain through “-reindex” by opening a terminal window in the Knots app.
Then I accidentally clicked on another corner of the screen and the terminal window went off. I know the command is still running because the used disk space keeps growing, but I would like to check the actual progress.
Any suggestion?
on the desktop right click on the icon and select troubleshoot. That is the file from debug.log on a normal installation.
Thank you. I tried but it downloaded the troubleshoot log file.
Instead, I was looking for the terminal log file (or resume an existing window) deriving from the Umbrel settings>Advanced settings>Terminal>app
