Accessing configuration file
I am trying to access the lnd config file and set
protocol.anchors=true
However I am getting “No such file or directory” when using “cat ~/.lnd/lnd.conf” OR “~/.lnd/lnd.conf”
Can someone help with this?
You should find it here
/home/umbrel/umbrel/lnd
or
/mnt/data/umbrel/lnd
Thanks!
gotcha, thanks!
hi i can’t find the config file (lnd.conf?) neither in umbrel/lnd (it says lnd is not a directory) nor on the mnt/data/ etc (same) ; has the path changed? many thanks
ok i figured it changed in 0.5 and is now in umbrel/app-data/lightning/data/lnd
