Hello … I have been connecting Sparrow Wallet (running MAC OS M-series 2.3.1) to my Electrs server (v 0.11.0) on Umbrel. But today when I opened Sparrow I received the following error …
“Connection failed: Unknown host error (umbrel.local: nodename nor servname provided, or not known).”
My settings on Sparrow remain unchanged … URL: umbrel.local ; port 50001
These settings match my electrs server (SSL disabled)
When I look at the server settings it says:
“Could not connect: Failed to resolve address umbrel.local”
The only thing I can think of is that I opened Sparrow when away from my node to check something. I wasn’t expecting it to connect to anything but didn’t think it would screw it up.
Was able to access my node with Sparrow using TOR, but really perplexed why my local network connection not working. Browser is connected to Umbrel.local, Knots, and Electrs.
This is a common DNS resolution issue. When you opened Sparrow away from your home network, your computer couldn’t resolve umbrel.local and may have cached that failure. Here’s how to fix it:
Most likely cause: Your Mac cached the DNS failure from when you were away. Steps 1-2 usually resolve it immediately once you’re back on your home network.
Thanks! I might just stay on TOR as I can access my Umbrel on the go. I another laptop at home that still connects Sparrow to UMBREL.LOCAL and I will test it out on that one. Thanks again!
