Since the update I can’t access to my lightning node so I lost all my bitcoin for now !!!
umbrel@umbrel:~$ sudo ~/umbrel/scripts/debug
0.5.4
Mem: 8.2G 1.4G 518M 606K 6.4G 6.8G
Swap: 4.3G 731M 3.6G
total: 17.2%
system: 17.2%
Memory monitor logs
2024-03-19 07:23:05 Memory monitor running!
2024-03-19 07:23:17 Memory monitor running!
2024-03-19 07:23:29 Memory monitor running!
2024-03-19 07:23:41 Memory monitor running!
2024-03-19 07:23:53 Memory monitor running!
2024-03-19 07:24:04 Memory monitor running!
2024-03-19 07:24:16 Memory monitor running!
2024-03-19 07:24:28 Memory monitor running!
2024-03-19 07:24:40 Memory monitor running!
overlay 48G 80M 46G 1% /
/dev/sda1 916G 667G 203G 77% /home/umbrel/umbrel
Karen logs
Got signal:
karen is getting triggered!
Got signal:
Docker containers
NAMES STATUS
lightning-terminal_web_1 Up About an hour
lightning-terminal_app_proxy_1 Up About an hour
lightning-terminal-tor_server-1 Up About an hour
bitcoin_server_1 Up 10 hours
bitcoin_i2pd_daemon_1 Up 10 hours
bitcoin_bitcoind_1 Up 10 hours
bitcoin_tor_1 Up 10 hours
bitcoin-tor_server-1 Up 10 hours
bitcoin_app_proxy_1 Up 10 hours
lightning_app_proxy_1 Up 10 hours
lightning_app_1 Up 10 hours
lightning-tor_server-1 Up 10 hours
lightning_tor_1 Up 10 hours
lightning_lnd_1 Up Less than a second
ride-the-lightning_web_1 Up 10 hours
ride-the-lightning_app_proxy_1 Up 10 hours
ride-the-lightning-tor_server-1 Up 10 hours
ride-the-lightning_boltz_1 Up 10 hours
Umbrel logs
/home/umbrel/umbrel/scripts/debug: line 131: docker-compose: command not found
Tor Proxy logs
/home/umbrel/umbrel/scripts/debug: line 137: docker-compose: command not found
This script requires “docker-compose” to be installed
==== Result ====
Please help me
