ERR_CONNECTION_REFUSED - Bitcoin node port 2100
Hello everyone,
the download from the bitcoin blockchain is working. If i click on “Bitcoin node” → http://umbrel.local:2100 i get the message " umbrel.local hat die Verbindung abgelehnt.
Versuche Folgendes:
  • Verbindung prüfen
  • Checking the proxy and the firewall
    ERR_CONNECTION_REFUSED"
What i tried:
  • firewall desactivated
  • router: port forwarding for port 2100
nothing helped
Can you please help me?
Thank you
BR
Elmar
umbrel-1738137868579.log (10.6 MB)
Same with me. It started suddenly. Many restarts and no solution yet.
Seems to be a common issue. I have not found any solutions to this issue.
Can anyone help?
Factory reset fixed this issue.
