Hello, I’m still trying to get to work my BTCPay Server app under Umbrel with clearnet access for e-commerce websites.
Someone from support send me this guide on how to create the reverse proxy to Tor, listed under te BTCPay Server docs: https://docs.btcpayserver.org/ReverseProxyToTor/
This works using a scout service that will proxy the requests directly to the app under the Umbrel node.
I have already managed to create the reverse proxy in a DigitalOcean droplet and when I visit the domain I can see the BTCPay login screen. The problem is that when I send the form I get an error 400 and a blank screen.
After some testing I have found that if I comment the next line I manage to login into the BTCPay Server app directly from my domain:
# Proxy requests to the socat service
location / {
proxy_pass http://127.0.0.1:9081/;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $remote_addr;
proxy_set_header X-Forwarded-Proto $proxy_x_forwarded_proto;
proxy_set_header Upgrade $http_upgrade;
#proxy_set_header Connection "upgrade";
proxy_http_version 1.1;
But commenting that will make the websockets not to work.
On the JS console I see:
WebSocket connection to 'wss://pay.xxx.es/Notifications/SubscribeUpdates' failed: Unexpected response code: 400
Error while connecting to websocket for notifications (callback)
Any ideas or workaround? Anyone has tested this setup?
Thanks
