HI ,I have a question about umbrel node. I ve been running my own Umbrel Bitcoin node on a raspberry pi for a few months now and solo mining BTC to it with a bitaxe 1.2th and just noticed that a block was found on my node i think (see Attached pic) can you explain this thanks for any help
First, that Block Height is very old for BTC which as of right now we are at 938,202.
Second, did you check your BTC Wallet?
Last, did you check your Miner to see what it’s highest difficulty it has achieved?
Hi Rod ,Thanks for the reply
Yes i check the block height and it looks like its from Feb 12, 2025 long before i setup my umbrel node ; thats what i dont understand.
I have checked and triple checked my BTC wallet its at 0 zero.
Did not check my miner difficulty?
Since i am a newbie to the Umbrel Node i was confused by the blocks found 1 in the software program can this mean that someone else on my umbrel node found a BTC block or my hosted public pool? Or that there is a software glitch in the program? Can it be malicious code embedded in my Bitaxe gamma that sent the Found BTC block to them?
My miner never showed any found block on the screen!
Again thanks for your help , hopefully i can figure this out
WAIT!!! That screen shot is from the “edit-widget” panel and not an Active Widget on your Umbrel WebUI!!!
On the edit-widget panel is where you select up-to 3 Active Web Widgets to display on your Umbrel WebUI!!!
Example:
That is where it will report your usage of your local node. In the “edit-widgets” is just sample data for the widget to display as part of the selection process!
