Bitfeed app doesn't start visualization
Hello,
I’m using Umbrel 0.4.13 on Raspberry Pi 4 and just installed Bitfeed.
The app opens, but the visualization doesn’t start (like it does on https://bits.monospace.live/). I just get the black screen and nothing happens.
Am I doing something wrong? I restarted Umbrel, but that didn’t help.
Thanks!
Avenor
Like mempool…space app, i don’t think umbrel Raspberrypi Arm64 can go that fast when indexing those transactions. So if you want more visualization you have to wait for like 4 min. In my test that when those transactions begin to look like on Bits.monospace.live.
Hi, thanks, but I’m afraid that’s not it.
I had Bitfeed open for over an hour now and there is nothing happening at all. It keeps saying “Mempool: 0 unconfirmed”.
The chain is 100% synced, and mempool.space works fine without errors.
I’d suggest uninstalling Bitfeed and then reinstall it, it might be a bad install. It happens sometimes.
That was it, DHD, you were right! That fixed it. Now the tx start dropping immediately after opening the app!
Thanks for your tip!
I’m glad that it’s working as intended now.
I installed mempool as my first app long time ago, and I kid you not, when I browsed to it, all I saw was B in a plain white page, and that’s the only text on there… I looked at the source HTML file, and it only had B. No matter what I did to try to fix it (restarting the node, forcing a refresh on the page, etc), I just decided to uninstall it and reinstall it, bam there it was working in its full glory.
Yes! I had the same issue, but reinstalled and it works like a charm. Beautiful app!
