Bitcoin 0.24 Stuck at "Starting" After the update of Bitcoin Core
I have updated to 0.24 for bitcoin but atm it’s stuck on starting (tried to reboot so many times) but not working.
https://imgur.com/a/bshSvrw
Any suggestions?
Same here.
I used Pi4 with umbrel 0.5.3
1 TB SSD
64 GB A2 SD
Same for me. Anyone found a fix?
Fixed for me: deleted all apps other than Lightning Node and Bitcoin Node. Bitcoin app then started, needed to sync a few missing blocks. Now working fine.
Other apps reinstalled, everything working fine now.
HI,
I am having the same problem with my node. don’t know what happened. not working for a few days now. i rebooted ( usual fix !). nothing happened.
i have a mini pc running ubuntu. so enougth power, enought memory …
i start umbrel (the User interface) all right . then I start the bitcoin node app. it just stay there syncing back and fourth . in starting mode…
i waited overnight to see if eventually he would catch up with somethong …? but same in the morning.
just in case i looked on a terminal window for a bitcoind process. can’t find any ( don 't know if there should be one but i thought so)
any idea ? i am starting to worry a bit …
thanks for your help
